help 7.3 2002
Old Oct 23, 2015 | 09:08 PM
  #31
Tim Hodgson's Avatar
Tim Hodgson
Read post # 30 and then the 3 and 4 pages.
I need a little help with a P1211 fault code - Page 3 - Ford Powerstroke Diesel Forum
  #32
Tim Hodgson
Double post.
Old Oct 23, 2015 | 09:09 PM
  #33
Tim Hodgson
Read post #30 here and then the last page:
Old Oct 23, 2015 | 09:11 PM
  #34
Tim Hodgson
Triple post.
Old Oct 23, 2015 | 09:25 PM
  #35
CampSpringsJohn's Avatar
CampSpringsJohn
What mods did you do in the tank?
Old Oct 23, 2015 | 09:34 PM
  #36
goose_ss4's Avatar
goose_ss4
Took the mixing chamber out. Extended and turned the return out of the way, and extended the pickup about a1/4" from the bottom
Cleaned and harpoon the filter and vent
Old Oct 23, 2015 | 09:54 PM
  #37
Tim Hodgson
So you now have a 3/8" opening to your fuel system? Or did you reuse the pickup foot? What did you find when you dropped the tank? I ask because you can search for F250_ (Pete's) forensic examination of the fuel pump it has a nonserviceable screen inside which is also capable of clogging.
Old Oct 23, 2015 | 09:57 PM
  #38
goose_ss4's Avatar
goose_ss4
I think whatever the tubing on the sender is. 5/16 I think
Old Oct 25, 2015 | 01:23 AM
  #39
Tim Hodgson
Not that it is your particular problem, but the concern about just running straight tube into the tank is that if a piece of foil from an additive or other debris gets sucked up against the tube, it can block it. That's why a lot of the guys here keep the foot and the foot screen (or get a new one) and push the tube past that little duckbill inlet. The foot is shaped like a bugle and has a very coarse screen and the area of the screen is much larger than the area of the opening of just the straight tube.
The reason I asked what debris you found when you dropped the tank is cause it could be clogging up the nonserviceable screen in the fuel pump. Some guys here have had success blowing air from the line at the fuel bowl back to the pump to the tank with the fuel fill cap off. If it runs ok after that, there is some debris somewhere along the fuel system.
That's all I got. Others can help you better from here, but they would probably like to see some codes pulled.
If you find something wrong, please come back and tell us.
When you fix the problem, please come back and tell us what it was.
Old Oct 25, 2015 | 01:27 AM
  #40
goose_ss4's Avatar
goose_ss4
Thanks for the concern bud, but my tank was mostly clear. Just did the mods because I had a filter I put on frame pre pump. Fuel pump is brand new.
I am having local guy making some hard lines to do my own fuel bowl delete. Tired of messing with it
Old Oct 25, 2015 | 01:32 AM
  #41
Tim Hodgson
10-4 .
Slash19
35
Jun 9, 2020 09:48 PM
mikenamys
115
Oct 5, 2015 05:41 PM
wastingas
Sep 17, 2015 09:25 AM
Mark.herbster
Aug 27, 2015 10:22 AM
SaintITC
21
Jun 16, 2015 02:26 PM
