coolant help
Old Oct 15, 2015 | 05:19 PM
peka's Avatar
peka
coolant help
94 f250 351w 4x4
Just changed water pump and stat and sender, filled with 50/50, squeezed upper hose to get air out. Kept overflow full and drove for 2 days. It drank coolant from overflow at night and I refilled it, it did not drink it all. On first day gauge was at 1/2 on day 2 gauge at 7/8 so I stopped and looked, all seems fine, overflow is 3/4 full. Restarted and gauge goes to 1/2 and stays there. I turn it off and wait 10-15 min and turn key on and gauge is at 7/8 I start it and gauge goes to 1/2. Is this normal? Stat stuck? Also upper hose when hot, there is so much pressure you cannot squeeze it, when cold it feels like there is no coolant in it Is this normal?
Old Oct 15, 2015 | 05:33 PM
maytag906's Avatar
maytag906
Sounds normal to me.
Old Oct 15, 2015 | 09:38 PM
ctubutis's Avatar
ctubutis
Sounds like it could be normal to me, too... ever since Ford changed how the senders & gauges operate (87 or 88ish) that gauge tends to suddenly read real high as soon as you shut the ignition off... possibly the gas gauge does the same thing, I don't remember.
But if I'm understanding you correctly, you don't have anything to worry about....
Old Oct 15, 2015 | 11:09 PM
peka's Avatar
peka
I misstyped it is a 84.
Old Oct 16, 2015 | 06:27 AM
ctubutis's Avatar
ctubutis
OK... Please clarify, then...
Originally Posted by peka
Just changed water pump and stat and sender, filled with 50/50, squeezed upper hose to get air out. Kept overflow full and drove for 2 days. It drank coolant from overflow at night and I refilled it, it did not drink it all. On first day is this before or after the two days you drove it described above? gauge was at 1/2 on day 2 gauge at 7/8 at what point of the driving cycle was this? IOW was it like that with the engine off? Or after having been running and had warmed up? so I stopped and looked, all seems fine, do you have a hand-held laser thermometer? overflow is 3/4 full. Restarted and gauge goes to 1/2 and stays there. after how much time after restarting the engine? I turn it off and wait 10-15 min and turn key on and gauge is at 7/8 I start it and gauge goes to 1/2. THIS is normal - the coolant absorbs heat but isn't circulating, the gauge will reflect that... but the gauge reads too high if you ask me Is this normal? Stat stuck? Also upper hose when hot, there is so much pressure you cannot squeeze it, that's normal when cold it feels like there is no coolant in it Is this normal?
The first thing I would do is verify the electrical connection at the temperature sending unit... if you remove that connector and turn the ignition switch on, the gauge should read full LOW... leave the switch on, now ground that wire; the gauge should read full HOT (don't leave the wire rounded like that for real long). That sending unit varies the resistance to ground, this is how it makes the dash needle swing back and forth.
But if you ask me, the gauge shouldn't be getting that far to the HOT side in normal operation... possibly the gauge us lying, possibly it really *is* getting that warm... which a hand-held laser thermometer can help you diagnose.
Old Oct 16, 2015 | 06:39 AM
ctubutis's Avatar
ctubutis
Another thing you could try kinda quickly is to put your old sending unit back in place and see if the gauge's behavior returns to something more normal (why did you change that thing, anyway?). I hope you didn't try to seal the threads with RTV or something like that, that device needs an electrical connection to ground through those threads and interfering with that can very easily cause the weird behavior you're seeing....
You can also put the thermostat in a small pot of water on the stove and watch it open up as the water heats up (which will happen kinda slowly, but it should be fully open at the time of its rated temperature).
Old Oct 16, 2015 | 01:45 PM
maytag906's Avatar
maytag906
One thing to remember, when you drive the truck, and shut it down, temp may climb slightly, because the coolant isn't moving. It should go down almost immediately.
Old Oct 16, 2015 | 02:05 PM
WhatsAChevy?'s Avatar
WhatsAChevy?
I'm wondering if teflon tape was used during installation of the new sending unit (coolant temp sensor).
Old Oct 16, 2015 | 02:21 PM
WhatsAChevy?
94 f250 351w 4x4
When You replaced all of this...did you open the heater core with the HVAC controls for complete system flow?
ten.mile
Jul 31, 2017 03:16 PM
mj_355
Feb 3, 2017 06:15 PM
85F350IDI
Apr 11, 2015 05:41 PM
tommyl
Feb 22, 2012 08:09 PM
rander101
May 21, 2003 10:09 PM
