Steering Damper Replacement
Old Oct 14, 2015 | 02:03 PM
Pony Power's Avatar
Pony Power
So I need to replace the steering damper and it looks like OEM replacement one is about $60. Is there better choices out there for around the same price. Would appreciate some suggestions. I get off road a few times a year for hunting and prospecting trips but no serious off roading.
Thanks
Old Oct 14, 2015 | 02:22 PM
holeshotwalt's Avatar
holeshotwalt
I replaced mine with a Bilstein 5100 for $79. Bigger shaft, seems more heavy duty than stock, looks great. No problems.
Bilstein 24 158848 Steering Damper | eBay
Old Oct 14, 2015 | 02:35 PM
Pony Power's Avatar
Pony Power
I've been thinking about Bilstein, they have a good rep or a KBY but don't know anything about that one.
Old Oct 14, 2015 | 05:28 PM
sudsmcduff's Avatar
sudsmcduff
Mine did not come with one. What are the advantages of having one?
Old Oct 14, 2015 | 06:03 PM
holeshotwalt
The big thing is that irregularities in the road are mostly toned down. Any bumps that affect one tire don't pull the steering wheel that way. Rain grooves and bad pavement finish that tug the wheel back or forth are mostly not felt.
If your rig is tight and you travel only great roads, you might not feel like you need one.
For most of us, they are an amazing, easy cure. It just lets you not think about it.
Add bigger tires and a little slop (mileage) in the rig, and it is a NECESSITY!
Old Oct 14, 2015 | 07:50 PM
Pony Power's Avatar
Pony Power
+1, I ordered the Bilstein. Amazon has it for $68.70 with free shipping. Should make cruzin with my 5th wheel a bit easier too. Spring time the shocks will be next.
Thanks Holeshot.
Old Oct 15, 2015 | 04:59 PM
brian42's Avatar
brian42
Veteran: Navy
I have a ProComp on mine right now and it's served me well (probably better than most). I go through them every couple of years with all the off-roading I do. If it doesn't wear out I end up taking some good hits on the trails (seriously, who decided to put that thing in front of the axle?).
I have a Rancho in the garage waiting to go on next time. I usually get whoever is having a sale when I'm looking to pick up another one.
Old Oct 20, 2015 | 04:47 PM
GEugeneS's Avatar
GEugeneS
replaced mine in 2007 cause truck would shake around 65. 8 years later, no problems with shaking. No off road except to get home as I live on a dirt road. About 1/3 mile of washboard, but only drive the truck on it 15 or 20 times a year.
Old Oct 21, 2015 | 05:39 AM
Tugly's Avatar
Tugly
I was told that the front dampener works best with a tired front end or with wide tires. Both make sense.
I can no longer test the tired front end theory, Stinky's nose is tight-tight-tight. I do have a vibration in the wheel at 65 MPH that drives me crazy, and I've been eyeing that bent-up dampener mount with nothing attached.
Old Oct 21, 2015 | 08:53 AM
Pony Power's Avatar
Pony Power
My front end still feels good, only have 90,000 on it. Have a rattle in front that sounded like a bad shock but they feel solid when trying to move them and they look good. However, the damper is wet so it must be leaking fluid. It didn't appear bent or loose so I'm replacing that and will see what happens. It should be here this week and then I'm off to the hills for a hunting trip. Will report back if that cured the bump rattle problem.
I have the stock 265 tires on so that's not it and looking at the damper mount it doesn't appear to be of much use being there. Maybe it only works after 60 mph.
Old Oct 21, 2015 | 10:26 AM
GEugeneS's Avatar
GEugeneS
Seems like $60-$80 might be a good gamble then. If it works, it's about half what a shrink would charge for just one visit!
Old Oct 21, 2015 | 10:29 AM
GEugeneS's Avatar
GEugeneS
Originally Posted by Pony Power
My front end still feels good, only have 90,000 on it. .
I had about 80,000 on mine when I changed it and I too have stock 265's on it. And I agree, it doesn't look like it would make much of a difference as mounted. But it made a huge difference on mine.
Old Oct 21, 2015 | 10:40 AM
holeshotwalt
I'd agree the more dramatic difference is felt on a worn front end, but for my dirt road travels and crappy Northern Calif. snow ravaged highways, the ease of driving is worth every nickel of a damper. With a tight front end, you have the direct connection to rain grooves, expansion joints, potholes, etc that are trying to take your wheels from their intended path.
I've actually installed aftermarket mounts/dampers on my other 2 trucks that didn't come with them.
Old Nov 10, 2015 | 11:20 PM
Pony Power's Avatar
Pony Power
Back from 10 days of logging roads plus snow and mud. I still have the metallic bang when hitting bumps so it wasn't the damper making the noise even though it was shot. Will replace the shocks next, prolly after Christmas. The steering does feel tighter on the rough roads but really didn't notice any difference going down the highway. My tailpipe broke loose from the muffler and the muffler shop said I need to replace both. I have a 3 1/2" system with I think a Walker flow through muffler. Anyone know where I might get the best deal on replacement parts?
Old Nov 10, 2015 | 11:24 PM
Nicmike's Avatar
Nicmike
Veteran/Sheepdog
Upgrading to a 4" exhaust will cost the same amount of money as the stock exhaust parts IMO. Magnaflow makes a good one at a decent price.
