Gauge cluster
Old Oct 13, 2015 | 09:28 PM
Ryan Fazzino's Avatar
Ryan Fazzino
Gauge cluster
I have a 1978 f250 ranger xlt, which gauge cluster do I use, the one that has 0-80 or 0-100, trying to make my truck as right as possible
Old Oct 14, 2015 | 01:49 PM
burnthelight88's Avatar
burnthelight88
85 I believe. If I remember correctly, the 100mph speedo was dropped mid-77. Well, scheduled to be dropped anyhow...like many things that Ford changed, they used the old ones until they ran out, so I've heard of at least 1 late '77 model with a 100.
But by the time your 78 was manufactured, I'd bet it was the 85.
Old Oct 14, 2015 | 03:36 PM
scottscott's Avatar
scottscott
85 MPH for 1978.
You'll need to know if the original cluster had oil & amp gauges, or warning lights for oil & amp. You can't install one where the other was originally, at least not easily. Gauge clusters use a plug roughly 2 1/8" long, warning light cluster plugs are slightly shorter.
Old Oct 15, 2015 | 08:24 AM
Ryan Fazzino
I got one from a 78 cab that was to 100 and the one in my 78 is 85 and then a 77 I picked up has 100 but has the lights instead of the needles
Old Oct 15, 2015 | 03:42 PM
scottscott's Avatar
scottscott
100 & 85 MPH clusters can sort of be swapped back & forth, but there are usually some differences that cause problems. Brake, hi beam & seat belt lights in different places, some have a low fuel economy light as well. The wiring is different for each type of cluster.
Mcrafty1
Apr 7, 2019 06:26 AM
jephwoyo
Jan 23, 2017 12:34 PM
HotrodSmurf
Jul 8, 2013 09:15 PM
sdloe
Jul 27, 2010 07:25 AM
ChadR93
Dec 4, 2001 03:28 PM
