Fuel Leak
Old Feb 22, 2002 | 02:22 PM
doboy3131's Avatar
doboy3131
Fuel Leak
I have a 1988 F-150 4x4 dual tank. Whenever I fill up the tanks I get a fuel leak just after I shut the truck down. It only leak an oz. or 2 untill I use about 5 gals. from each tank. There is no gas leaking when the truck is running. I was thinking it had to do with the switching unit.
Old Feb 22, 2002 | 08:51 PM
brett_d's Avatar
brett_d
Fuel Leak
Sounds like the gasket that goes from your fuel pumps to the the tank is not sealed properly. I just installed two new in-tank fuel pumps on my rig and it took alot of time to make sure the gaskets were aligned properly.
Old Feb 22, 2002 | 11:12 PM
doboy3131's Avatar
doboy3131
Fuel Leak
Thanks,but what I don't understand is that it only leaks after the truck has been shut down for 15 min. or so. I did replace the rear pump and I will check if I kinked a line on top of the tank. My best guess is that the fuel line is remaining pressurized and leaks from the top of the tanks. This will happen to whichever full tank I am running.
Old Feb 23, 2002 | 06:58 AM
brett_d's Avatar
brett_d
Fuel Leak
If you park your vehicle on a downgrade so the front is alot lower than the rear it should leak heavily because the pump connection is to the front of the tank!
Old Feb 23, 2002 | 07:01 AM
brett_d's Avatar
brett_d
Fuel Leak
cgi2099
Dec 9, 2011 12:03 PM
fordsuperduty250
Sep 20, 2011 01:04 PM
60RatRod
Oct 12, 2010 08:08 AM
mstepchinski
Jun 27, 2005 11:23 PM
