Rear fuel tank Leaking while running help?!
I have an 81 F150 4x4 with a C6 351M
I have been having an on going problem with my rear fuel tank leaking from the top when any gas is in it (as little as 5 gallons) while the truck is running (doesn't leak if the truck isnt running). Does anyone know what could cause this?
Thank You,
Josh
Thank You,
Josh
My 81 rear tank had the same symptom, my problem was a rotten rubber fuel hose between the tank and steel line.
I would crawl under there and replace ALL the rubber fuel hoses as they're all 30 yo and in pretty much the same condition.
I dropped my tanks although some will say it can be done without doing that but I think it'd be more of PITA that way.
I don't remember the fuel hose sizes but I *think* they were all the same.
TexasGuy001
May 3, 2018 09:54 AM
lkm96
Apr 1, 2017 08:57 AM
Hotairjunkie
Jul 20, 2009 05:08 PM
redneckf350
Mar 21, 2005 11:41 AM
