EGR Valve????
Old Feb 22, 2002 | 07:45 PM
Saxon's Avatar
Saxon
Post EGR Valve????
My engine, '89 4.9L, has a bad miss-stumble to it while driving, either accelerating or cruising. I read all the post about blocking off the EGR valve and it made no difference. I also drilled a .250" hole in the aluminum plate that I used to block off the valve and that made no difference. It also happens during hard acceleration. I checked the timing = 10 degrees. The spark plugs and Belden wires have 20,000 miles on'em, and look good. New fuel filter installed. If it was the fuel pump shouldn't I also have bad idling?
Thanks All,
1989 F-150 300-6 M5OD 4x4 3.08 133,000 mi.
Old Feb 22, 2002 | 10:05 PM
PAUL_2's Avatar
PAUL_2
EGR Valve????
Old Feb 22, 2002 | 10:11 PM
PAUL_2's Avatar
PAUL_2
EGR Valve????
Spark plugs with 20K miles on them in the 4.9L ...Its time to change them . Its up to you , But Id recommend the Motorcraft Plugs , BSF 44C gapped at .042 to .046 In . Check for diagnostic trouble codes & fuel pressure . When was the last time the distributor cap & rotor was replaced , As well as fuel & air filters ?
Old Feb 23, 2002 | 07:53 AM
Saxon's Avatar
Saxon
EGR Valve????
All other ignition compoments also have 20k mi. on them.
How do you check fuel pressure?
Is the fuel regulator inside the pump?
Old Feb 23, 2002 | 08:55 AM
PAUL_2's Avatar
PAUL_2
EGR Valve????
There is a shrader valve on fuel rail located at the back of the fuel rail , close to the firewall on the right side of the engine . Youll have to install a fuel psi gauge to that valve & turn the key to run to check the fuel psi . The fuel pump regulator is part of the fuel rail & its located toward the front of the rail . It will have a red vacuum hose attached to it .
