distributer
Old Aug 4, 2003 | 04:29 PM
JERR's Avatar
JERR
Unhappy distributer
Is it hard for a novice to put in a new distributer or does it just need the cap replaced?I have a 95 f150 with 161000 miles on it and never have done either to it.It has a miss even after new plugs and plug wires.Or is it not the distributer at all?
Old Aug 4, 2003 | 05:17 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
distributer
Since I don't have any idea what engine you have I'll just throw out some ideas here. Make absolutely sure that you didn't get your firing order wrong. Second, check the gap on your plugs is set right. I once put in a set of plugs on my truck and on the boxes the plugs came in said pre-gapped, so I put them in without a second thought. Then for three days I kept beatin my head against the wall trying to figure out why my 300 was misfiring. Finally pulled the plugs and checked the gap. One plug barely even had a gap(that one misfired), and another plug had no gap(wasn't even firing, dead cyclinder). For future reference, please post what engine and any other piece of information that has to deal with the problem you are having. It helps us to help you. Other than that, Welcome to FTE !
Old Aug 4, 2003 | 05:42 PM
JERR's Avatar
JERR
distributer
Sorry.Its a 6 cylinder 4.9liter. The gaps are what they are suppose to be.I only changed 1 plug wire at a time so I would not screw up the order.
Old Aug 4, 2003 | 05:55 PM
dtpatt2's Avatar
dtpatt2
distributer
change the cap and rotor before the whole distributor...
Old Aug 4, 2003 | 06:25 PM
90f150moneypit's Avatar
90f150moneypit
distributer
Also as a habbit, I always replace the O2 sensor at every tune up just so I know it is as fresh as the plugs. Just an idea.
WalterRoad
Feb 8, 2015 01:56 PM
SIXTFOR
May 23, 2014 04:06 PM
Mike in Ohio
Apr 22, 2012 08:00 AM
thebarnyard13
28
Feb 29, 2008 12:31 PM
