Speaker install
Old Oct 12, 2015 | 10:21 AM
51fred's Avatar
51fred
Speaker install
I have an original 6v electric wiper installed in my 51 F1. I am trying to install the speaker on the original bracket and can't get it into position with the wiper motor interfering. I have loosened up the wiper assembly to try and gain clearance but to no avail. Is there a special trick or do I need to find a special speaker? Can I cut a relief in the speaker magnet? I am going to install an original 6v radio as well.
Old Oct 12, 2015 | 10:36 AM
firstrider's Avatar
firstrider
Rich,had no problem with mine . Do you have a correct speaker? That maybe the problem.i know things are tight in that area . Modifying the speaker magnet may not be a good idea . Yeah 2000 posts .
Old Oct 12, 2015 | 11:05 AM
51fred's Avatar
51fred
Thanks Denny, I suspect that is the case. I will keep looking. I was hoping to get the under-dash done so I could install the firewall cover and that nice Magic-Air heater. It's been over 10 years in the making so far so no use in rushing now!
Old Oct 12, 2015 | 10:50 PM
gearhead1952's Avatar
gearhead1952
Can you post a pic of the speaker? The magnet might be too big if it is a modern 6X9. Also needs to be 4 ohm.
Old Oct 13, 2015 | 12:07 AM
51fred's Avatar
51fred
Here is a picture. I bought it as for the 51-52 truck with the wire and connector.
Old Oct 14, 2015 | 08:40 AM
51fred's Avatar
51fred
This speaker is supposed to be for 48-52 trucks. Does it resemble ones others have used?
SPINPOSI
Nov 21, 2008 12:16 AM
ididntdoit99
Nov 30, 2007 12:23 AM
wcsd106
Aug 13, 2006 11:18 PM
ctch88
1978 - 1996 Big Bronco
Mar 15, 2004 08:28 PM
mrit
Sep 2, 2003 02:05 PM
