Need fix for radiator
Old Oct 12, 2015 | 08:41 AM
2005 Ex Limited's Avatar
2005 Ex Limited
I changed the idler/tensioner, and broke the overflow nipple off of the radiator putting the shround back on. Probably not a fix for this since it's plastic (thinking self-tapping-bulk-head-fitting) but I'll probably end up replacing the whole unit.
Anyone have a fix, or know where I can not spend $400 for a new one?
Old Oct 12, 2015 | 08:44 AM
KIDkiser's Avatar
KIDkiser
There is a way to fix,I think diesel tech Ron shows you how on YouTube.
Old Oct 12, 2015 | 10:12 AM
2005 Ex Limited
Props given.
Old Oct 12, 2015 | 12:16 PM
bobv60's Avatar
bobv60
Yep. I didn't use a video, drill and tap 1/8 npt ad bass pip to hose nipple.
Old Oct 12, 2015 | 12:24 PM
walrus's Avatar
walrus
The 1/8 npt nipple works.. I did it after testing the load bearing weight of the original plastic nipple..
Test results: The plastic nipple will not support my full lean on it like an idiot weight.
Old Oct 14, 2015 | 07:27 AM
2005 Ex Limited
There was another video that shows taking the fan off. When he goes to re-install it he was underneath pulling the tabs out to get the shroud seated correctly. Well I was underneath pulling the tabs out the get the shroud seated correctly.
Sometimes things just don't work out. No matter how you prepare, or act.
My only worry is that when I tap into the plastic that a little piece will end up in the system. Given my luck it won't matter because this will work, but I will end up getting hit by a train.
Old Oct 14, 2015 | 12:14 PM
1977scoutii's Avatar
1977scoutii
Don't use the epoxy, it won't last long (a few months). Use something specific for radiator repair (available at your local autoparts store) to use as a thread sealer on your nipple after you tap the hole. Id also recommend going in with a plastic fitting like nylon as opposed to brass. The brass will want to separate from the radiator material and thread sealer over time as well. Or at least this has been my experience.
Old Oct 14, 2015 | 04:33 PM
Rusty Axlerod's Avatar
Rusty Axlerod
If you put a brass fitting in there, the fitting will become the best part of the radiator.
Old Oct 15, 2015 | 05:50 PM
2005 Ex Limited
Only thing I'm worried about is the galvanic corrosion between the copper and aluminum. Time will tell. Going to try it tonight, and I'll let you know how it goes.
It wanted a 7/16" hole for the tap, but I only had a 3/8". Right angle drill to get that in, and some pipe dope and all is good. Ran it around to really warm it up and it didn't drip a drop. Call this a win.
Old Oct 16, 2015 | 07:30 AM
TooManyToys.'s Avatar
TooManyToys.
Galvanic corrosion would only be a problem if the metals were in direct contact with each other.
To confirm the earlier poster: Just about all retail epoxies are not waterproof and will fail in time with hot water.
Old Oct 16, 2015 | 08:05 AM
2005 Ex Limited
Correct. With water above 200° the solubility will increase enough to allow more than usual amounts of copper to dissolve within the water. This will inevitably come in contact with the aluminum of the radiator and therefore we act in manner as if it was in direct contact. I would have preferred to do a plastic fitting, but home depot didn't have one. I will end up bullet proofing this next winter probably, so I don't have to worry about it long term.
I do agree with the epoxy. Unless you find one designed for use underwater it will fail rather quickly. That would be a short term fix, mine a moderate interval, and a plastic the indefinite.
Old Oct 16, 2015 | 10:45 AM
joe blow's Avatar
joe blow
You know you can go to performance radiator.com and buy the EXACT radiator BPD sells for 248.00 shipped free. Your repair will eventually fail.....why chance it?
Aluminum tanked NO PLASTIC
https://shop.performanceradiator.com...roduct_id=5515
Old Oct 16, 2015 | 12:46 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
If you want to stick with the OEM solution, we can set you up with Motorcraft OEM for $275 as well.
Old Oct 20, 2015 | 06:11 PM
2005 Ex Limited
I never noticed that. Guess everyone has to make a few bucks huh.
Down the road I'll bulletproof it, but this will work for now.
Pridnjoy
Sep 17, 2021 08:23 AM
04scurs
Jan 9, 2019 01:41 AM
cowmilker08
Feb 11, 2014 09:41 AM
oldschool888
6.4L Power Stroke Diesel
25
Nov 12, 2013 07:16 PM
ericnewmanconst
Feb 3, 2011 01:19 AM
