Value for 1941 F100
Old Oct 11, 2015 | 06:04 PM
pstadnyk's Avatar
pstadnyk
Value for 1941 F100
I recently found an all-steel, all-original manual trans 41 F100 with the original flathead v8 (that isn't running but turns freely).
The truck is very straight and very complete with no rust. Mileage is unknown.
What's it worth?
Old Oct 11, 2015 | 10:09 PM
newold46's Avatar
newold46
The truck is worth whatever the buyer is willing to put up. Depending on your part of the country, some sellers want your first born or a limb or two for rusted out junk. Other parts of the country are more reasonable.
A '41 Ford is just called a truck. F1 started in '48, F100 started sometime in the '50s I think.
Old Oct 11, 2015 | 10:14 PM
pstadnyk's Avatar
pstadnyk
Well it's coming out of KC and seller is asking 12k, again no rust or body damage.
Are the flat heads easy to rebuild? Ir am I getting myself into something expensive?
Old Oct 11, 2015 | 10:30 PM
newold46's Avatar
newold46
12K??? That thing should be completely finished and road-worthy for that kind of cash!
Flatheads are reasonably easy to work on depending on your plans. Lots of places sell lots and lots of old Ford parts just for the V-8.
Old Oct 11, 2015 | 10:48 PM
pstadnyk's Avatar
pstadnyk
Well it's also a bit more collectible being that's from a vintage gas station called Polly Gas - it still has all the logos and address markings on it.
I've looked around and haven't seen running original 40-41 pickups for less than 22k
I added pics!!!
Old Oct 12, 2015 | 08:21 AM
newold46's Avatar
newold46
Very nice but still not a 12k truck. That's what I call "New truck money" as in- you should just buy a new one instead.
Old Oct 12, 2015 | 10:10 AM
christurney77's Avatar
christurney77
Does it have a clean title? If it does, then that helps. If you are going to keep it for a long time and are willing to put another 10k +/- in it, the you should have a decent truck. I do think 6 to 8k range is more like the actual price.
Here is a couple references:
http://desmoines.craigslist.org/cto/5240520730.html
http://www.ebay.com/itm/Ford-Other-Pickups-hot-rod-/141796196455?forcerrptr=true&hash=item2103b64067&item=141796196455
Old Oct 12, 2015 | 11:02 AM
newold46's Avatar
newold46
Here is another:
https://desmoines.craigslist.org/cto/5261946274.html
Old Oct 13, 2015 | 09:14 AM
mr.precision's Avatar
mr.precision
Here in Arizona it would bring 12K if running properly and rust free as you describe. Out on the west coast, it would easily fetch 12K.... and if running perhaps 14-16K. But that's Commifornia for you.
I'd say 8K would be a good purchase. Flatheads are not cheap to rebuild, and since it doesn't run you have no idea what else doesn't work properly.
Old Oct 15, 2015 | 01:38 AM
Crewcabber's Avatar
Crewcabber
It has one thing going for it. It has the 41 hood waterfall. Hopefully it's in good shape. I don't think the 12k is unreasonable it looks complete but like mentioned above your going to spend some money on refinishing it. The cabs are notorious for cracking from behind the door openings. Cab corners rust out fairly common as well. Check the passenger side manifold see if it still has the factory exhaust with the can and heat element. This stuff is all worth some money if you decide to buy it and not restore it.
My dad and I restored this one. Almost completely original with flathead and original 4 speed crash box trans.
There us no filter used on this picture I was extremely lucky to catch the sun at the right angle while she waited her turn to get the exhaust done.
Old Oct 15, 2015 | 09:27 AM
christurney77
Beautiful truck there Crewcabber!!!
Old Oct 15, 2015 | 10:31 AM
tacomacream's Avatar
tacomacream
'41
Old Oct 24, 2015 | 04:18 PM
Lumbah's Avatar
Lumbah
Here's a similar truck, although less complete.
1939 Ford Pick up
Old Oct 24, 2015 | 04:19 PM
Lumbah's Avatar
Lumbah
Old Oct 26, 2015 | 11:50 AM
christurney77
Chris... Looks like your next project!
hesm8891
Aug 15, 2015 12:03 PM
windiabbie
Jun 8, 2007 06:58 PM
Jfrost
Jul 11, 2006 04:57 PM
GreatNorthWoods
Car/truck Buying Advice
Jul 25, 2002 01:47 PM
