Damaged Gear?
Old Aug 4, 2003 | 03:22 PM
BigFootnHawse's Avatar
BigFootnHawse
Damaged Gear?
Quick question for the axle gurus. I was looking through some of my spare parts (gears, carriers, steering linkage, etc.) and noticed some of the pinion gears have small chips on the outer edge of the gear (the larger diameter side). These chips are not in the wear area (not where the gears contact each other), and thus I would think would not affect the performance. Some pinions have only one chip, others have 2 chips.
Are these gears OK to use or should they be scrapped?
Thanks,
Old Aug 4, 2003 | 11:29 PM
steve83's Avatar
steve83
Damaged Gear?
Unless you can match them to the original rings that they wore in with, I'd never use them in a rear axle. Maybe in a front since it's not used all day every day...
Old Aug 5, 2003 | 08:18 AM
BigFootnHawse
Damaged Gear?
Steve, I do have the matching ring and pinions, I was just referencing the pinion chips. But you don't see a problem with reusing them if it is not in the wear area?
Old Aug 5, 2003 | 11:15 AM
RRMike's Avatar
RRMike
Damaged Gear?
How did they chip? Were they tossed around a scrap pile or something like that? If they came out chipped that would make me wonder a little.
Old Aug 5, 2003 | 11:27 AM
BigFootnHawse
Damaged Gear?
I am 99.99999% sure they were damaged either during the removal or just being stacked/moved around and stored. The ring gears look perfect with a centered wear pattern. The chips are located at the thinnest and most vulnerable point on the teeth, and thus all the chipped teeth are consistent in appearance (look as though they were dropped on a concrete slab or other hard surface.
So am I right in assuming they should be OK to re-use?
Old Aug 5, 2003 | 05:46 PM
RRMike's Avatar
RRMike
Damaged Gear?
I would use them if it wasn't my brand new superduty. I would use them in my backup rig or 4 wheelin' rig. Worst that can happen is you waste them and have to buy new ones anyway.
Bad1993
1978 - 1996 Big Bronco
Nov 23, 2016 09:52 PM
johnstonmatt77
Nov 17, 2015 02:19 PM
Rob Cuenin
Jan 7, 2005 05:11 AM
wyldstallyn73
Dec 19, 2004 09:33 AM
wldcat65
Computer Chips & Tuners
Nov 6, 2004 10:27 PM
