Computer Chips & Tuners
Computer Chip options?
Old Nov 2, 2004 | 09:15 PM
wldcat65's Avatar
wldcat65
I have a 1997 Expedition 4X4 w/ 3.73 gears. What are my chip options? What are the pros and cons? Any problems to watch for?
Old Nov 6, 2004 | 10:27 PM
FTE Ken's Avatar
FTE Ken
With tuners, there are three options:
With tuners, no PCM code is needed. You plug it into the diagnostic port, it reads your computer and figures out what the PCM code is. It then loads the correct tune into your vehicle.
Superchips Microtuner - works with 1996-2003 F-150, Expedition, etc.. Includes a basic diagnostic code reader. Three power modes: 87 octane, premium fuel for towing, premium fuel for max performance. You can adjust shift points, shift firmness, rev and speed limiters and calibrate the speedo for tire and gear changes.
Diablo Sport Predator - works with 1999-2003 F-150, Expedition, etc. Includes an advanced diagnostic code reader. Standard power mode is premium fuel plus it can be adjusted for virtually any octane fuel. You can adjust shift points, shift firmness, rev and speed limiters and calibrate the speedo for tire and gear changes. Plus you can adjust fueling, ignition timing and more. Added bonus of being able to update it via the web with a download.
Superchips Custom Tuner - (1996-2005 applications) we program this for your specific application. Holds three power settings, and we consult with you on the phone about which settings you want and any custom needs you have. Contains a basic diagnostic code reader. Allows you to adjust timing and fueling (to a mild degree, not as much as the Predator). You can adjust shift points, shift firmness, rev and speed limiters and calibrate the speedo for tire and gear changes, and adjust idle revs.
A chip (Diablo or SCT) is preprogrammed by us and you can't adjust it. Its the least expensive choice. Any of the above options will work for your application.
Here's how to make the choice:
1. Diablo chip - lowest price, great performance. http://www.motorhaven.com/customer/home.php?cat=37
2. Diablo Predator - won't work for your year.
3. Superchips Microtuner - works with the largest variety of Ford trucks and suvs (not an issue with your model/year). Basic diagnostic code reader. Simplest to use but not as flexiable as a Diablo Predatorr. Good power, but on average the Predator will give more. http://www.motorhaven.com/customer/home.php?cat=169 - put 1000 in the coupon code at checkout for a special discount.
4. Superchips Custom Tuner (SCT) - generally for custom applications and heavily modified vehicles. http://www.motorhaven.com/customer/home.php?cat=274
5. Superchips Custom chip - 4 program settings plus stock, plus kill switch function. All 4 programs are custom programmed. Switchable on the fly lots of bang for the buck. http://www.motorhaven.com/customer/p...cat=274&page=1
Haywire-Powerstroke
24
Apr 20, 2015 08:14 PM
softailjeff
May 16, 2014 01:55 PM
The Big Hazer
Jan 4, 2012 09:13 AM
Dutch123
Feb 10, 2003 08:07 PM
mild 02
3.8 & 4.2L V6
Sep 3, 2002 12:12 PM
