Another black tank question
Old Oct 14, 2015 | 06:43 PM
scraprat's Avatar
scraprat
Top Answer: 5
Ok, I actually watch more or less the 2nd video in full. It was pretty interesting. I'm sure if you wanted to you could pick it apart but in theory it has the working idea of whats happening. My 5th has the built in flush and I use it after I dump the tank and it is something how must "stuff" comes out.
Old Oct 15, 2015 | 10:13 AM
BPofMD's Avatar
BPofMD
FTE Remembers
Veteran: Navy
....especially the TP! But I have noticed a GREAT difference that how much LESS TP is stuck to the sides of the tank now that the water softener has made the sides so slick!
Old Oct 16, 2015 | 10:35 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
When I'm dumping I start the the flush before I open the valve, I think it gets things stirred up plus it gets more water in there to help getting the waste moving. My flush system has a tube running the length of the tank with multiple outlets and I think it does a good job but I've never looked in there. I didn't watch the whole video it looked like a long winded sales pitch.
Denny
Old Oct 18, 2015 | 11:30 AM
r2millers's Avatar
r2millers
Inspired me to go back to water softener crystals or the like. Not sure if he does that test too?
I also have the San I Tee flush system and I run it while flushing and then, close off the valve several times to get that additional flush (providing there isn't a line, waiting behind me and staring).
I have also used cooking oil at times and that seems to lube the valve assemblies a bit.
Old Oct 18, 2015 | 04:03 PM
Good listener's Avatar
Good listener
X2 There will always be a box of water softener in our trailer after trying it out this weekend. Quite amazing how clear the tank is when used with laundry detergent. This will be our waste tank MO for all future trips.
Old Oct 21, 2015 | 08:40 AM
CR3999!'s Avatar
CR3999!
Bud thanks for the tip. I'm a full timer, at times the odor makes me empty the tank prematurely. I also run a flush King. Had to get one, I open the valve and nothing came out. Now the cable to the black tank broke. ( something broke, cable, the connection I haven't looked at it yet. It's a pita with a basement cover )
Old Oct 21, 2015 | 08:59 AM
Good listener
Cut the underbelly material with a razor knife. When finished with your repair patch the cut with underbelly tape
http://www.amazon.com/4x50-Mobile-Polyethylene-Underbelly-Repair/dp/B00VB9U4B4/ref=pd_sim_60_3?ie=UTF8&refRID=19FP81C2XXYBVZ58D0GV&dpID=41OVM8aWf4L&dpSrc=sims&preST=_AC_UL160_SR160%2C160_ http://www.amazon.com/4x50-Mobile-Polyethylene-Underbelly-Repair/dp/B00VB9U4B4/ref=pd_sim_60_3?ie=UTF8&refRID=19FP81C2XXYBVZ58D0GV&dpID=41OVM8aWf4L&dpSrc=sims&preST=_AC_UL160_SR160%2C160_
. This is quick and saves a lot of hassle.
Old Oct 21, 2015 | 09:36 AM
RV_Tech's Avatar
RV_Tech
Cable connection at the valve.
Steve
Old Oct 21, 2015 | 09:41 AM
rvpuller's Avatar
rvpuller
If you are getting odors between dumps check and make sure your toilet is holding water, if not get a kit to repair it.
Denny
Old Oct 21, 2015 | 11:02 AM
CR3999!'s Avatar
CR3999!
I like that tape idea, it gets good reviews. Yes, Denny the tank is holding water. And Steve I'm sure your right. Either at the valve or the handle behind the wall. That handle has always been a chore to close. The cable may be binding some where. Thanks guys!
Old Oct 21, 2015 | 12:51 PM
rvpuller's Avatar
rvpuller
I didn't mean the tank but the toilet itself if you are getting a smell inside the rig.
Old Oct 21, 2015 | 01:47 PM
Good listener
The tape works great. Just wipe down the area with rubbing alcohol before you apply it. It's a bugger to get the release film off if it's cold. Once on, won't come off. Good luck and please update with your findings!
Old Oct 28, 2015 | 11:43 AM
  #28
KW7DSP's Avatar
KW7DSP
I have the same problem as the original poster. A bad seal that lets liquid leak off. I try to keep about twenty gallons in the tank to keep the pipe full and use an external twist on valve.
The biggest mistake full timers and long-term campers make is to leave open the black water valve while in an RV Park. You "MUST" leave it closed and dump it when it gets over 2/3 full, but never let it just drain or you will get a 50 gallon cake of fertilizer. I have three 100 gallon tanks in my big 5th wheel and I lived in it full time for three years. I learned the routine of use/hold/dump. for the black water the hard way.
grantorinosport
Jul 29, 2017 10:00 PM
hanklin
All Things Towing
60
Jun 16, 2014 01:13 PM
AlexWV
6.7L Power Stroke Diesel
22
Dec 29, 2011 06:28 AM
n8ishooiam
Mar 23, 2011 01:13 PM
6.9OriginalDiesel
Jun 15, 2007 08:44 AM
