does the 02 have a lighting control module??
Old Oct 10, 2015 | 11:42 AM
tjc transport's Avatar
tjc transport
i ain't rite
like the title reads, i am wondering if the 02 has a lighting control module.
i lost headlights and fog lights last night
all fuses are good, all bulbs are good, and power is going into and out of the headlight switch.
but no power to the headlights or fog lights.
i tagged into the output wires on the light switch to trigger 60 amp relays, and drew power for the relays off the batteries to get the lights working again.
Old Oct 10, 2015 | 11:56 AM
Absolute's Avatar
Absolute
Mine was a Texas truck, so had no DRL module. An after market one was installed to meet Canadian law. It went and caused what you are experiencing. So if its a Canadian truck, it will have a module, if not it will not.
Old Oct 10, 2015 | 12:01 PM
Absolute's Avatar
Absolute
Your going to need to see if power is on the outlet side of the headlight fuse. Power goes from the light switch to the relay to the fuse to the lights. So power at the switch outlet is not a clue. Is power exiting the box (fuse)? Then test that wire for continuity to the lights. Also check your grounds. In fact I would check the grounds first. That's real common.
Old Oct 10, 2015 | 12:08 PM
Thomas White's Avatar
Thomas White
Those functions are controlled by the VSS Module on mid 01 and later. A totally different animal than the earlier GEM and RKE Systems.
Old Oct 10, 2015 | 12:54 PM
tjc transport
i ain't rite
all fuses are good and power is coming out of the fuse box. power is also coming out of the light switch, just not out front to the lights.
that is what i thought. i guess it will stay bypassed and wired up with the relays like i currently have it.
radiosandstuff
Feb 4, 2019 08:11 PM
1percenter
Apr 1, 2017 06:30 AM
omni
Jan 27, 2015 09:06 PM
jmmranger
Oct 28, 2011 09:42 PM
vancouver island
Oct 22, 2009 04:44 AM
