Cac boot replacement
Old Oct 10, 2015 | 08:16 AM
Magnolia Tom's Avatar
Magnolia Tom
Had the lower hot side CAC boot blow out on me. I replaced it with an OEM part. Should I also replace the upper boot?
Old Oct 10, 2015 | 08:21 AM
npccpartsman's Avatar
npccpartsman
11 1/2 year old 220K truck and the only one I've replaced is the hot side at the turbo (with OEM boot). Seen 38 psi boost on them all many many times and not had a problem......yet. I wouldn't.
Old Oct 10, 2015 | 08:37 AM
Magnolia Tom
Ok. So no need to replace them in pairs? I thought the upper one goes bad faster or more often than the lower. Don't want to be stranded towing the fifth wheel again.
Old Oct 10, 2015 | 08:40 AM
npccpartsman
It does, so you might want to do it while you have the pipe out or at least put a spare in the truck.
Old Oct 10, 2015 | 08:41 AM
Magnolia Tom
Thanks. I'll replace it just to be safe
MaxOut
Jan 19, 2017 12:48 PM
timbrady
Aug 13, 2014 09:19 AM
malodin
Jan 18, 2011 11:45 AM
schlepprock250
31
Jul 25, 2009 12:20 AM
dchamberlain
Mar 13, 2009 04:35 PM
