Bronco II Ford Bronco II
Bronco II Wheel Adapters
Old Oct 9, 2015 | 08:21 PM
tsytsa's Avatar
tsytsa
Hello all, I have a 1988 Bronco II that I want/need to put wheel adapters on. I've never done anything like this before so I was wondering if I could get some tips/advice on installing, brands, size range, and whatever else I'm missing. Also, what's a good place or site to buy them at? Thanks!
Old Oct 9, 2015 | 11:07 PM
85e150's Avatar
85e150
What are you trying to adapt to? The pattern for the BII is 5 on 4.5". Billions served, millions from the BII, Ranger and Explorer will fit. (16x7 from Explorer for example would be quite an upgrade from the 15 x 5.5" stocker)
If you are thinking of putting some huge tires on it, think again. The axles are not going to like that.
Old Oct 10, 2015 | 12:48 AM
tsytsa's Avatar
tsytsa
Yeah I bought it with 31's on it. I wanted to space the wheels out a bit so the tires won't hit anything. I'm not really trying to adapt to a different size, just want to use the adapters as spacers. I heard I shouldn't use spacers if I plan to go 2" out.
Old Oct 10, 2015 | 01:38 PM
Josh S's Avatar
Josh S
Spacers probably aren't going to be your best option then. Think of the traction beams as levers. As you space the wheel out farther the force exerted on the ball joints, coil springs, etc. increases. You will wear your ball joints much faster but more importantly it will throw off your wheel camber causing the tires to wear faster on the inside. It will almost certainly mess with your steering too.
Some other options:
A 3" body lift would help wheel clearance a lot and could be purchased for about $200 including body mount bushings. I have 30"x9.5 tires and my 2" body lift makes everything clear nicely.
Another avenue, depending on what kind of condition your body is in, you could cut a little off the wheel wells and cover with aftermarket fender flares.
Or put on some stock tires to improve your mileage, road handling and gear ratio. Even just running 30's my 5th gear is almost useless.
Old Oct 10, 2015 | 04:31 PM
tsytsa's Avatar
tsytsa
I was actually considering a lift kit after spacers. Especially since I would probably need at least 2" spacers. Is a 3" lift the highest that would be recommended on a BII, or can I go a bit higher?
Old Jan 6, 2016 | 11:50 AM
AZFX4's Avatar
AZFX4
Personally Im not a fan of body lifts. Go with some coil spacers up front and an add A leaf in the rear and you will be much better off and will fit 31's just fine.
jason90f150
Jun 4, 2016 08:45 AM
Edds
1978 - 1996 Big Bronco
Feb 11, 2015 04:01 PM
MonsterTruck\m/
Feb 7, 2012 08:10 PM
yukgoon
Aug 3, 2010 01:13 AM
white ford power
Apr 13, 2003 11:01 PM
