460 Leak Eviction
460 Leak Eviction
Ok, 96 F350, 460 and a 4 speed auto. I've got a significant coolant leak that doesn't leave drips. Looking around in the engine bay I see wetness around the intake to head gasket, and I would really like to think that the wetness along the head to block gasket is just from the intake gasket.
I'm going to order new intake gaskets and redo those. Truck is high mileage and not maintained over the last few years before it came into my hands. Originally a fleet vehicle and theoretically well maintained over that time, but not driven by people who cared about it.
I'm planning on having a two week window during the evenings to work the thing over. Should I just cut my losses and do the head gaskets now? Is there anything else I should think about doing while I'm in there? Truck will be going on a nice long haul over the mountains to Nevada after my maintenance window is up, and I don't want to be picking up a crate 460 at summit (well I do, but not for this truck).
Any tips or good write-ups on the intake gaskets?
I looked more in detail at pulling the heads and decided I want to avoid it if possible. Plan right now is to just go for the intake and then if I need to do something else I'll make arrangements after it makes the reno trip.
That said, anything else I should look at while I've got the intake off?
Ok, got the intake off, really pissed I had to pull the dizzy to do it. Double pissed that I didn't index anything before I did that.
Gallon and a half of oil in the intake and vacuum lines, added a new pcv valve to the list.
One of the injectors fell apart in my hand. Ordered rebuilt and flow matches ones.
I didn't realize this was an egr engine. Any reason not to use a special port NOT matched gasket for that on reassembly?
Camshaft doesn't look too scored, any test I can do on the heads before I throw things back together?
Anything else I'm missing?
Current parts list:
T-stat, gasket
New intake gaskets
injectors
bypass hose
PCV
Current parts list:
T-stat, gasket
New intake gaskets
injectors
bypass hose
PCV
No test worth doing while I'm in here?
I'm not gonna have time to rip the heads off before I need it running again, unless I'm severely underestimating that job. I'm thinking it wants a new timing cover though, and I know I need to fix an exhaust leak.
And new shocks.
But it's gotta be at the show twice a month and it's not my money, I just drive it and fix it.
And new shocks.
tjnthesky
09-18-2014 10:53 PM
monsterbaby
1983 - 2012 Ranger & B-Series
19
06-06-2012 07:55 PM
JetMech07
27
04-04-2011 07:36 PM
mswift
06-17-2006 02:19 PM
78bigunns
09-08-2002 12:14 AM
