Preparing for winter...
Old Oct 9, 2015 | 09:28 AM
Scum Frg's Avatar
Scum Frg
Why not just bring the truck in and get it rust-proofed.
Up here Krown and Zeebart are popular.
Old Oct 9, 2015 | 09:56 AM
tspangle84's Avatar
tspangle84
Here's a thread I started on this same topic a few years ago: https://www.ford-trucks.com/forums/1...st-at-bay.html
Long story short, I'm a big believer in Fluid Film. My truck gets a coat every fall, in fact it's going to get one this weekend.
As for the "beater with a heater" thing, I did that once when I had a new Mustang. Never again. I'm not making payments on a nice vehicle (especially a 4WD truck!) just to drive some old POS for a third of the year. I'll do what I can to protect it, but I'm going to drive it. That's why I have it.
Old Oct 9, 2015 | 11:01 AM
Liam_Harrow's Avatar
Liam_Harrow
Just read part of that thread. My truck has similar surface rust as yours did on the transmission crossmember and some other spots scattered around. Do you suggest applying por-15 before fluid film? How did that work out?
Old Oct 9, 2015 | 12:28 PM
tspangle84's Avatar
tspangle84
Pretty good so far. I think I might touch it up this time around, but it seems to be holding up a lot better than the factory coating did. The worst area under the truck now after four winters is the front control arms and knuckles, they are looking quite rusty.
Old Oct 9, 2015 | 02:07 PM
Liam_Harrow
Did you ever paint your rear axle and differential? The rear axle in entirety is surface rust.
Old Oct 9, 2015 | 03:19 PM
tspangle84's Avatar
tspangle84
No, I'm too lazy. That's a big area, and lots of stuff in the way to work around. Plus POR-15 is expensive stuff! So I spray it with FF and hope for the best. I'm honestly not that worried, there's a ton of metal there, and if it was that critical that it stay corrosion-free, Ford would have coated it with something from the factory.
Old Oct 9, 2015 | 07:59 PM
Liam_Harrow
That's what I was thinking too. The wires for the ELD and eveything would make it interesting. I'm going to paint my rockers and control arms I think.
Old Oct 11, 2015 | 07:19 AM
D8chumley's Avatar
D8chumley
Resident smarta$$
Originally Posted by bakon
Maybe you misunderstand. I use it same way as you. Exact way. I just don't hi pressure spray it off all winter long as I believe it could start removing the product with repeat spraying. I might use a garden hose to wash the truck and hit some spots seen standing but in general I leave it be and the salt would be on the outside with fluid film between it and the body.
How much does the FF cost? One of my buddies at work is from western PA, and he gets his truck underside coated with waste oil when he goes back home this time of year. Don't know where he gets it done, but IIRC it cost like $75ish and he is happy with the results, gets it done before winter every year. I wish there was a place near me i do my rear wheel wells and a few other spots with a small sprayer
Old Oct 11, 2015 | 10:48 AM
fordman19762003's Avatar
fordman19762003
Fluid Film is around $40/gallon from the Rust Store. The Undercoating gun is $30. A gallon of Fluid film is enough to do a fullsize truck about three times(at least for me). I also buy the aerosol fluid Film for inside the doors and rockers because it's thinner and runs down into the seams better. Cans are around $10/each, plus for another $14 you can get an extension hose with a 360* nozzle to really do a good job inside the enclosed areas.
About spraying FF inside the doors and rockers. I do it on my super duty because the bottom of the doors has a pinch seem and it is prone to rusting. There are drains just above the pinch seem and at each corner. I have not noticed these to get plugged. The F150's has a somewhat open channel along the bottom of the door and I will spray a light coating of FF in that then blow the excess out with air. also anytime I drive in wet conditions or wash the truck I will blow the water out of the seam. This method worked on my '05 F150 to keep the doors rust free for 10yrs and going.
I spray the inside of the rockers and keep an eye on them. After three years on one truck and two on the other there is no noticeable dust accumulation inside the rockers that will plug the drains.
Old Oct 15, 2015 | 07:13 PM
xr7gt390's Avatar
xr7gt390
I try to avoid car washes. Things may have changed in the 30 years since I last worked at one. At the time we recycled water, used hash chemicals (some contained acid) & strong detergents to blast off dirt and grim. I just picture all the salt and crap getting rinsed off the car in front of me, then mixed with acid and blasted at high pressure on my car, no thanks.
Old Oct 15, 2015 | 07:29 PM
Liam_Harrow
I've never really liked car washes because I always thought about how much dirt, grime, salt, and dust those huge vertical cloth things and the rotating brushes collect after touching all those cars. And especially during the winter
Old Oct 15, 2015 | 10:52 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I only use touchless carwashes.
I'm sure glad the only winter prep i have to do is throw my snow tires on, some weight in the back, tow strap and jumper cables......along with some arctic gear lol.
Old Oct 16, 2015 | 04:26 PM
  #28
the_auto_tech's Avatar
the_auto_tech
Anyone on here running snow tires? I am debating a setup for this truck as I plan to keep it for a while. Last year I had the 06 F-250 with 35x12.50x18 Goodyear Duratracs. It was ok in the snow, but not what I'd consider very much fun. Sadly because of the lift I couldn't run a smaller tire or it would have looked ridiculous. This time though I just plan on a leveling kit, so I'd imagine I can get away with a bit more tire and wheel wise.
Old Oct 16, 2015 | 04:42 PM
  #29
kruzer's Avatar
kruzer
As a longtime and old New Englander in age, I've used the suggestions mentioned. I've also accepted that rust is like taxes and death. Do what you can to avoid it but it's going to happen.
Old Oct 17, 2015 | 03:06 AM
  #30
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I have Blizzaks on my F-150, Cooper M+S studded on my Excursion...love them both! Also ran Firestone winterforce on my Expedition previous to the current Blizzaks.
