New Alternator Issues
Old Oct 6, 2015 | 06:56 PM
mwoj's Avatar
mwoj
So I got a new alternator for my 360 because the bearings were speaking really bad. After researching some more about it, I learned that I'm supposed to have spacers on the bolts. There weren't any when I took it off, so this is probably why the bearings were messed up. I made a spacer for the bottom out of some washers but didn't make one for the top. Anyways, when I went to connect the battery, the terminal started sparking when I went to put on the cable.
This has never happened before so I'm thinking I messed up putting on the new alternator. Also, when I started it up there was a burning plastic smell. One thing I noticed is that one of the connectors on the back of the alternator is really close to the block. I'm worried that it might be arcing across. Today when I went to start it, my battery was totally dead. Any suggestions? Also, where can I pick up the alternator spacers? Thanks.
EDIT: I don't know how important this is, but one of the three connectors didn't fit so I soldered a different connector onto the alternator harness so that it would fit. Again, this may or may not be part of the problem.
Old Oct 6, 2015 | 08:28 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Make sure and always disconnect the battery cable when working on/removing the alternator. Was the spark a little one of a giant one? A little spark like when you hook up a batter charger is ok or normal to me.
Did you make sure and get an externally voltage regulated alternator? I believe there is a difference? The close to the block connector should have a rubber boot with a 90 on it.
Old Oct 16, 2015 | 05:35 PM
mwoj's Avatar
mwoj
Ok so here's my alternator. Name:  WOgciIe.jpg
The bolt in the bottom left of the picture sits extremely close to the block, I'm not sure if that's causing it to short or what. I had it wired up like this: black wire with black connector cap to STA. Orange/red wire with red connector cap to BAT. Black wire with silver loop to FLD. Is this correct?
Here's how it sits in the truck. Name:  zG7O8la.jpg
Old Oct 16, 2015 | 05:59 PM
mwoj's Avatar
mwoj
Here's a rough picture of how I had it wired. That connector at the base of the rubber part holding the wires together bolts to that bolt to the right of it. Name:  QKBhiWS.jpg
Old Oct 16, 2015 | 10:54 PM
mwoj's Avatar
mwoj
Anyone? There's a Caffeine and Carburetors on Sunday that I would like to bring the truck to.
Old Oct 17, 2015 | 03:22 AM
crazedfox's Avatar
crazedfox
You may have connected it wrong & fried the Alt.
So go get it tested/Replaced then try this:
Alt. wiring on a 1975' truck.
Black with red-stripe wire to Bat. terminal.
(It's a 10-Ga. wire, the fat one.)
Orange wire to FLD. terminal.
White with black-stripe to STA. terminal.
P.S.
Make sure the Battery is charged (12v. min.),
& get your voltage regulator tested as well.
Old Oct 17, 2015 | 01:56 PM
mwoj's Avatar
mwoj
So we found out what the burning smell was: I fried the voltage regulator last time. I put on a new one, installed the alternator, fired it up and it instantly went up in smoke. Another voltage regulator in the garbage. What's the deal?
Old Oct 17, 2015 | 03:34 PM
crazedfox's Avatar
crazedfox
Did you apply the wiring code I put in my last post?
Old Oct 21, 2015 | 08:52 PM
mwoj's Avatar
mwoj
Thanks crazedfox, I got it working now
zoom38
39
Mar 30, 2018 01:53 PM
Walleye Hunter
Jun 1, 2016 06:17 AM
pstrokelover
May 21, 2014 05:36 AM
fordtruck661
Aug 3, 2013 09:23 PM
Raider949
13
Dec 22, 2012 07:31 AM
