351 swap out for 390?
Hey all, new guy here with my first thread. Hopefully, I dug far enough back through the swap forum (and didn't find my specific question) that it's cool to start my own.
Truck A: 1977 F-250, 4WD, 351M engine, 4-speed manual truck trans
Truck B: 1963 F-100, 2WD, 390 engine, C6 auto trans (390 is out of a 1970 2WD)
What I want to do: Put the 390 into the 1977, using the 4-speed manual trans.
Is it as simple as getting a clutch/flywheel/bellhousing for the 390 and making the swap? or no?
Please and thanks
Please and thanks
You'll need the flywheel for the 390, a pressure plate that will work with that flywheel and a clutch disk that will work with that pressure plate and the trans input shaft. If you're lucky a 390 clutch disk and pressure plate will work with your trans input shaft, but it's not necessarily a guarantee.
Then you'll need the bellhousing for the 390 and hope that the trans will bolt up to it and the input shaft will be the right length.
You'll need a pilot bearing that will fit in the 390 flywheel and on the trans input shaft.
And you'll probably need a manual starter for the 390.
All of this might just fall together, or it might be the start of a nightmare. Sorry, but I have no idea which.
That's why he needs the bellhousing for the 390.
Possible I suppose, but I wouldn't think it was too risky. Manual transmissions were awfully common in '63, so I'd guess all the cranks would work with a manual trans
It's not a no-brainer, but I wouldn't be too scared of it.
bignative64
09-29-2009 02:20 AM
SuperSnake
05-17-2008 07:31 PM
JermKline
04-03-2006 10:38 AM
86302
07-17-2005 02:43 PM
2onetons
07-17-2003 08:25 AM
