89 E250 striker bolt bushing
Old Oct 5, 2015 | 10:37 AM
Ranger88Den's Avatar
Ranger88Den
I have a 1989 Ford E-250 with a worn out rear door plastic striker bolt bushing. Does anyone have a fix or know of a source? TIA
Old Oct 5, 2015 | 01:02 PM
annaleigh's Avatar
annaleigh
On my 90 TC, the PO used a piece of pvc pipe cut to the right length..
acording to Ford -- <table><tbody><tr><td>
</td> <td>Ford
</td> <td>E150
</td> <td>1980-1991
</td></tr></tbody></table>Ford Part No.: E9AZ-5422008-A Striker - Door Locking Mechanism
E9AZ-5422008-A - Genuine Ford Striker - Door Locking Mechanism
also might look here but it is a package of 50
Ford Door Lock Striker Bushing 1/2 I.D. 11/16 O.D.
complete striker and bolt here with free shipping
http://www.ebay.com/itm/Dorman-38448...-/351118944411
Old Oct 5, 2015 | 01:09 PM
annaleigh's Avatar
annaleigh
dorman part 38448,,, local parts store may have it on their little racks with special parts not listed in the computer
Old Oct 5, 2015 | 01:58 PM
JWA's Avatar
JWA
Amazon also shows that part under a different number, looks about the same:
Amazon.com: Ford 6W1Z-5422008-A - STRIKER - DOOR LOCKI: Automotive Amazon.com: Ford 6W1Z-5422008-A - STRIKER - DOOR LOCKI: Automotive
BTW that was found by entering the Ford part number Annaleigh shared into a Google search.
Old Oct 5, 2015 | 02:50 PM
Ranger88Den
annaleigh & JWA, thank you so much for the responses. I'll get on it ASAP.
Old Oct 5, 2015 | 02:59 PM
annaleigh's Avatar
annaleigh
I need some bushings for my van and my moms van as all the doors rattle and they have no bushings left! I would need 8 total so I am going to make my own..
According to the parts list the bushings are 1/2 I.D. 11/16 O.D.
You can buy short pieces of pvc or pex pipe at the local builders supply.
this link gives you the od and id of common pipe
http://www.nomacoinsulation.com/pdf/...A32%200909.pdf
I know 1/2 id pipe slides right over the door lock bolt.. SO the OD is what needs to be matched..
1/2 PVC has too large of an od.. = .840
1/2 PEX is just a bit under 11/16 = .625 but that is what was used on my lincoln and the doors close great.
3/8 PVC measures .675,,, that is between 21/32 and 11/16,,, that is just 1/32 smaller and the 3/8 PVC could easily be driller out to 1/2
this is providing that my math is right!!
Old Oct 5, 2015 | 03:04 PM
annaleigh's Avatar
annaleigh
opps my math is wrong! The difference between 21/32 and 11/16 would be around 1/64th i think!
Old Oct 5, 2015 | 03:33 PM
Ranger88Den
It's all good. I appreciate all the quick and timely responses.
Old Oct 5, 2015 | 08:31 PM
jbwheels's Avatar
jbwheels
I used the PEX tubing you can buy at Home Depot to make bushings for my Town Car. Amazing what a difference the bushings make.
Old Oct 5, 2015 | 10:55 PM
Ranger88Den
Thank you. I appreciate all the suggestions and replies. Good community.
Old Oct 6, 2015 | 01:10 PM
Ranger88Den
I ended up using 1/2" PVC water pipe, but had to ream it out with a 1/2" drill bit. It's working fine. Thanks again for all the ideas & suggestions.
Old Oct 6, 2015 | 04:02 PM
annaleigh's Avatar
annaleigh
Glad you got it done and thanks for letting us know how it worked. Your bolt must be slightly bigger then 1/2". I will have to get busy and do mine now!
Old Oct 6, 2015 | 04:24 PM
annaleigh's Avatar
annaleigh
one thought.. you know your lock twice, you know the first lock and then you push a bit more and the door locks tight? The OD of 1/2 PVC according to the chart is .840 and that would be 21/25.. The Ford replacement bushing is 11/16.. 21/25 is quite a bit larger for the lock lock around.....
Old Oct 6, 2015 | 04:30 PM
Ranger88Den
Only know it's working well, maybe due to wear on the latch.
Old Oct 6, 2015 | 04:51 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
According to Ford Part Number: E9AZ-5422008-A (replaced EOTZ-1022008-A) .. Striker Plate / Available from Ford & auto parts stores.
Applications: 1980/91 Econoline: Right & Left Front Doors; Body Side Hinged Door / 1980/91 F100/350 & Bronco front doors / 1983/89 Crown Vic/Grand Marquis front/rear doors.
1983/86 Mustang/Capri / 1983/86 LTD/Marquis (mid-size Fox body) front/rear doors / 1987/89 Town Car front/rear doors / 1987/89 Mustang.
Econoline rear doors, sliding door use different striker plates (see parts catalog apps below). Ford only sold the nylon bushing with the striker plate.
6W1Z-5422008-A (replaced F2AZ-5422008-A; E9FZ-5822008-A; E1FZ-6122008-A) .. Striker Plate is not listed for any 1991 or earlier Econoline.
