75 f250 highboy cummins conversion
Do you see the blue line with User CP, Albums, FAQ? See the SEARCH on that line? It has a drop down search menu arrow. Go to the "Advanced Search"option, top left side (search block), type in there what you are looking for. And then go to the lower right column and highlight 73-79forum. Select it and then you will have a detailed search just in the 73-79 forums. There are some threads that cover the wiring.
https://www.ford-trucks.com/forums/1...=cummings+swap
IMO here is the diesel conversion guru to ask. Check out his thread. https://www.ford-trucks.com/forums/1...rns+oil+burner
Thanks I'm not try to do much fab work because I'm not to good with it. Do u thing the motor mounts from https://www.dieselconversion.com would be able to bolt up to mine.
hunter101
05-13-2022 12:55 AM
martinez53
10-14-2010 11:13 AM
