Explorer disc brake conversion
Old Aug 15, 2017 | 04:04 PM
  #31
davewild's Avatar
davewild
Originally Posted by monkey-1
This is an increase if distance from the wheel mounting flange to the rear end bearing end, correct? .......
Correct, Disc brake axles are something like 1.88" offset and this disc brake setup requires an 2.5" offset along with most aftermarket brake setup in order to center the rotor correctly in the Brake caliper bracket.
Old Aug 16, 2017 | 04:34 PM
  #32
davewild's Avatar
davewild
Opps that should read drum brake axles are like 1.88" offset and disc are 2.5"
Old Aug 16, 2017 | 09:08 PM
  #33
monkey-1's Avatar
monkey-1
Thanks Dave for all of the info and the write up on this conversion. I am getting so much different information from different companies, I have decided to tear this axle down and take some measurements before ordering any parts. This thing is pretty crusty and needs a pinion seal at the very minimum (but will get more than that). I did find this in the web and it may be helpful to some doing this or a similar swap.
Edit:
I have spoken to 3 different companies that specialize in Ford 9 inch rear ends and received 3 different answers to some of my questions. Two of the companies have expressed to me that the bearing ends (the shapes) are not a good way to determine if Explorer style brakes will bolt up. The measurements should be 2 inches up and down and 3.562 across. The picture above will need to be measured and be 2.50 inches. SOME axles may be the right offset, but this isn't the norm. Thanks to Dave (reps sent) for allowing us to junk up his thread with all of this information.
Old Aug 17, 2017 | 12:00 PM
  #34
davewild's Avatar
davewild
The flange and bolt pattern dimensions (4 bolt hole locations) determine if the explorer brake bracket will mount up. The axle flange offset determines where the rotor centers within that brake bracket to line up in the caliper.
Old Jan 29, 2018 | 10:42 PM
  #35
davewild's Avatar
davewild
Just rode this thing about 4000ish miles, besides a leaky axle seal all worked flawlessly!
Old Jun 7, 2018 | 11:02 AM
  #36
shaker666's Avatar
shaker666
Just getting started on the Explorer brake conversion on my '79 Bronco with factory 31-spline 9" rear. I've read on this forum that these brakes can be adapted with some minor mods to the early big bearing Ford flange, so going for it! I've got the Currie spacers and 5x5.5" rotors, so we'll see how she goes... I noticed that the e-brake assembly from the Explorer looks to be a direct drop-in to the '79 Ford, so that is a nice thing, for sure!
12ozd
16
Nov 6, 2014 02:13 PM
Kuskoal
Nov 8, 2008 04:54 AM
jecsd1
Jun 16, 2008 03:00 PM
truck35
1966 - 1977 Early Broncos
Jan 24, 2004 10:41 AM
bhabben
Jan 21, 2003 11:18 PM
