Sponsored by: Real Truck
Won't start, no codes TRUCK STARTED
Old Oct 1, 2015 | 07:54 PM
azplumber's Avatar
azplumber
Any help would be greatly appreciated, 2004 F350 4x4 DRW. The truck just keeps cranking over until the batteries start getting weak. Neither my SCT programmer or my Scan Guage 2 throw any codes. Yesterday I put on a new belt, after reconnecting everything the truck started up and ran fine. today I put on new rotors and pads and now the truck won't fire. When I go to start the truck, it makes all the usual sounds, and cranks over and over and over but wont fire, with out any codes Im at a loss.
Old Oct 1, 2015 | 08:01 PM
Just Strokin's Avatar
Just Strokin
How about some info on your truck? Engine would be helpful. Does the tach move when cranking the engine?
Old Oct 1, 2015 | 08:13 PM
azplumber's Avatar
azplumber
oh sorry, 2004 F350 Lariat DRW 4x4 6.0 PSD,6" lift w/ dual steering stabilizers, 35" Toyo M/T, 4" exhaust turbo back, (removed cat,) SCT program, ARP head studs, blue spring, BPD oil cooler w/ remote filter, BPD EGR valve, Sinister coolant filter, MagHytech front and rear diffs, MagHytech trans pan, red top Optima batteries, upgraded alternator wire, battery to battery wire and grounds. New high output Alt is on its way. I hope that helps. Im at a loss. Thanks in advance for any suggestions.
Old Oct 1, 2015 | 09:16 PM
azplumber's Avatar
azplumber
sorry again, no the tach does not move
Old Oct 1, 2015 | 11:25 PM
azplumber's Avatar
azplumber
Alright, never mind. It started. I still don't know what caused it not to start. But it starts now. I just sprayed a little starting fluid into the airfilter and bingo, bango, bongo we are up and running. It has started several times now so I believe its all good.
mech1
Oct 11, 2021 11:37 PM
Restlesswildman
Dec 27, 2016 10:42 PM
xxdbkxx
Oct 24, 2013 12:41 PM
duckskinner
May 15, 2013 10:38 AM
77f2504by4
Jan 9, 2005 06:53 PM
