4.9 Plastic Timing Gears
Old Sep 29, 2015 | 11:24 PM
carmexjoe's Avatar
carmexjoe
I apologize in advance if this has been covered elsewhere but I haven't been able to find any information on it. When did ford start putting plastic timing gears on the 4.9? I currently bomb around in a lovable yet crusty 81 F-100 and am wondering if I should pick up a set of steel gears as a preventative measure.
Old Sep 29, 2015 | 11:29 PM
85e150's Avatar
85e150
Probably in 1965.
Do you notice any plastic debris in the oil when you change it?
Any strange noises from the timing set area?
Old Sep 29, 2015 | 11:33 PM
carmexjoe's Avatar
carmexjoe
No plastic debris and it makes the same squeaks, grunts and kerchugging sounds that its always made.
Old Sep 29, 2015 | 11:44 PM
85e150's Avatar
85e150
Just run it..... Serving suggestion.
Old Sep 30, 2015 | 07:25 AM
Franklin2's Avatar
Franklin2
They do wear out once in awhile. I have never worked on a six, but I seem to remember one of the gears is phenolic, not plastic. The v8's had the plastic coated aluminum gears that likes to break off and get in the oil pump suction screen.
Phenolic is layers of some sort of fabric soaked in a resin and then compressed. It's pretty good stuff, but of course like anything it will wear over time.
Old Sep 30, 2015 | 09:48 AM
1986F150six's Avatar
1986F150six
My 1986 4.9L has 187,350 miles with the original phenolic gear with no problems.
My son's 1984 with same power train has over 237,000 miles and is still original.
Old Sep 30, 2015 | 11:35 AM
82F100SWB's Avatar
82F100SWB
My 82 had steel gears, my 84 had the phenolic and aluminum. Your 81 should be steel gears.
Old Sep 30, 2015 | 11:47 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1965/74 factory installed 240/300 I-6 timing gear is plastic. 1975 and later 300 I-6 factory installed timing gear is phenolic.
Old Sep 30, 2015 | 01:04 PM
1986F150six
I never knew that, NumberDummy. Thank you!
Old Sep 30, 2015 | 06:36 PM
maytag906's Avatar
maytag906
I had an 86, 4.9, that the phenolic timing gears went out on. I replaced them with steel. Those things whined like it had a 6:71 blower on it.
79super460
Sep 1, 2012 09:29 PM
bigbrown84truck
Oct 18, 2005 12:45 AM
stan merck
1978 - 1996 Big Bronco
May 30, 2004 03:36 PM
lawnbiz
Feb 13, 2004 03:47 PM
Walking_Tall_0403
Oct 29, 2003 03:06 PM
