egt gauges
Old Sep 29, 2015 | 06:28 PM
scotttahoe's Avatar
scotttahoe
Originally Posted by Sous
I am interested in installing an EGT probe as well, but am nervous because I have never used a thread tap and don't want to screw up the manifold and create a big problem where one does not exist now.
Replied to your PM.
Old Sep 29, 2015 | 06:30 PM
bcg's Avatar
bcg
When I put mine in, it was the first time I'd ever used a thread tap as well. There really isn't anything to it. If you can drill a straight hole and screw something in, you've got the required skills.
I put mine in the up pipe just past the manifold. That way, even if you do screw it up, it's just replacing an up pipe (or welding the hole back up).
Old Sep 29, 2015 | 06:33 PM
binuya's Avatar
binuya
I was also apprehensive about drilling and tapping my manifold, but as it turns out, it was by far the easiest part of my gauge installation. I used the instructions from Diesel Manor: 3-Gauge Install Pictures
Old Sep 29, 2015 | 09:33 PM
HD Rider's Avatar
HD Rider
Just how big is your phone?
How can you see and read all your gauges on that little screen?
Old Sep 29, 2015 | 09:51 PM
hydro man 17's Avatar
hydro man 17
[QUOTE]I am interested in installing an EGT probe as well, but am nervous because I have never used a thread tap and don't want to screw up the manifold and create a big problem where one does not exist now[/QUOTE
Just make sure that you have the proper sized drill for the tap size and back out the tap every couple of turns to clear the chips. Cast iron is very brittle yet it can feel "sticky" at the same time. Trying to force it can lead to a broken tap. Major PITA
Old Sep 30, 2015 | 05:57 AM
Tugly's Avatar
Tugly
Originally Posted by bcg
...So far, I've found this for Android - FORScan Home....
Alas, it looks like the world finally cut loose of our caboose. Our technology goes back a ways, so we are dangling at the end of the train of OBDII protocols. I looked in the list of protocols supported by Forscan (creepy name), and our beloved J1850 PWM wasn't on the list.
He probably has one of these:
Old Sep 30, 2015 | 07:03 AM
bcg's Avatar
bcg
It does work though, I took a chance on it for the $5 and was able to connect to my truck with my bluetooth OBDII adapter and it read codes from all they systems, gave me live data, etc.
Old Sep 30, 2015 | 08:50 AM
Tugly's Avatar
Tugly
Very cool. That was a happy Discovery. I'll give it a try, but the name still creeps me out.
Old Sep 30, 2015 | 11:52 AM
bcg's Avatar
bcg
You gotta get your mind outta the gutter, man. Think of it as a shortened version of "Ford Scanner" instead of where you're going with it...
Old Oct 1, 2015 | 01:56 AM
Tugly's Avatar
Tugly
Gutter? This isn't the whole world? There's more over the rim?
Old Oct 1, 2015 | 10:10 PM
HD Rider's Avatar
HD Rider
Don't believe it Tugly!
It's a trap!
Old Oct 1, 2015 | 10:49 PM
hydro man 17
"Gutter? This isn't the whole world? There's more over the rim?"
Some people still think it is flat.
Old Oct 2, 2015 | 07:14 AM
  #28
JOHN2001's Avatar
JOHN2001
Dual egts. I highly recommend them
Old Oct 2, 2015 | 07:22 AM
  #29
scottddove's Avatar
scottddove
Please give reasons to have duel egt's.
Old Oct 2, 2015 | 08:21 AM
  #30
JOHN2001's Avatar
JOHN2001
Ever had an uvch problem? You'd be chasing that if you didn't have 2 gauges to compare. I diagnosed mine in a split second with a glance.
Same goes for a boost leak on the intake.
What if you looked over randomly driving down the road and seen a 300 degree or more difference? I've been there. If it wasn't for the gauge I would have never known something was wrong.
I believe it was Joey who melted a piston because he only had 1 gauge. He has 2 now.
It's normal to see 50-100 degree difference any more than that it's questionable
