Power steering help
Old Sep 28, 2015 | 07:17 PM
62 ford owner's Avatar
62 ford owner
Power steering help
I have an issue my 62 ford started leaking power steering fluid bad from the control valve and the problem I'm having is finding a rebuilt unit the control valve on it is a garrison and I have found one but the female end on the new one is bigger then the one I have and I need help finding the right one. Also would the bendix unit go in its place easily any help would be great.
Old Sep 28, 2015 | 09:18 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Unless you have an F800/1100, P/S was not available, so whatever type it has was swapped in from something else.
AFAIK, Garrison Power Assist P/S was only used on the following: 1973/75 F100 4WD & 1975 F150 4WD / 1973 F250 4WD / 1974 F250 4WD before serial number T80,001.
Old Sep 28, 2015 | 09:53 PM
62 ford owner
I know it wasn't stock it looks added by how the inner fender was cut for the lines but if you or anyone now if a latter bendix control valve would fit that would be great and did anyone make kits for these things back then?
Old Sep 29, 2015 | 06:53 AM
NumberDummy
You cannot swap a Bendix Power Assist P/S control valve for the Garrison type, as it's a completely different system.
Plus, Bendix was only used on F250 4WD's, and the Bendix parts are much harder to find than Garrison parts.
D3TZ-3A650-A .. Garrison Power Assist P/S Control Valve Seal Kit / Obsolete
WESLEY OBSOLETE PARTS in Liberty KY has 1 = 606=787-5293.
MCDONALD OBSOLETE PARTS in Rockport IN has 1 = 812-359-4965.
MILLER OBSOLETE PARTS in Binghamton NY has 3 = 607-722-5371.
Upper pic: Garrison / Lower pic: Bendix.
Old Sep 29, 2015 | 05:25 PM
62 ford owner
Thanks for the help I have figured out how to make it work with a replacement 73-79 control valve. Thanks for the help.
YoungDumbAndBroke
Mar 24, 2019 09:36 AM
jleeper
Aug 31, 2015 09:23 PM
rtonam
Feb 7, 2014 01:18 PM
redrider8293
Sep 21, 2012 10:11 AM
big-ugly
Aug 25, 2012 05:19 PM
