ball joint press question.
Old Sep 28, 2015 | 10:17 AM
tanman722001's Avatar
tanman722001
Im going to be changing the ball joints on my 97 f350 2wd. Will this toolnwork or do I need to get the extra kit along with it?
http://www.ebay.com/itm/301750630206?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old Sep 28, 2015 | 03:34 PM
wag53's Avatar
wag53
I think I'd be leery of that one. Rented one from auto parts to do mine on sig vehicle, cost $250, had more adapters and was steel C-frame. Took quite a bit of force to get them out & in. That aluminium C-frame probably won't take stress.
Old Sep 28, 2015 | 03:36 PM
Hoppkins's Avatar
Hoppkins
Honestly you would be better off renting one from an auto parts. I did ball joints on a 2002 f250 with a cheap press like that and the spine of it bent like nothing. Instead of looking like a C it looked like a 3. They aren't even worth what they are asking. Just my opinion. We had rented it and it was $200 but when you were done with it you got your $200 back in full. It's a big chunk but 1000% worth it.
Old Sep 28, 2015 | 09:03 PM
Toplait's Avatar
Toplait
I was looking at the Harbor freight ball joint press. Was thinking about buying one also...
Old Sep 28, 2015 | 09:06 PM
Hoppkins's Avatar
Hoppkins
That's the one I bought. Complete garbage. Don't waste the cash.
Old Sep 29, 2015 | 02:15 AM
sgip2000's Avatar
sgip2000
This is the one I have. Steel and very heavy!
http://www.ebay.com/itm/201013246486...S:3160&vxp=mtr
Old Oct 4, 2015 | 02:04 PM
AKHunter93's Avatar
AKHunter93
A c-clamp ball joint press being made of aluminum does not mean it won't take the stress. Aluminum is much stronger than most understand.
I bought one before I did the ball joints on my F-250, and I ended up only using it to remove the old joints. I ended up taking the steering knuckles and new ball joints to the local tire shop, and they pressed them in for a whopping $50. It would've saved me a bunch of money to just forego the press and pay them to remove the old ones, too. Food for thought.
Old Oct 4, 2015 | 02:35 PM
bashby's Avatar
bashby
You don't need a press to remove them. I have had an OTC press for 25 years that I bought used and it still works fine. I do not have the extra accessories, just pretty much what is in the kit you show. I second the autozone or advance tool loaner program, you pay for it, use it, and get your money back when you take it back.
Old Oct 6, 2015 | 01:24 AM
privateer, eh's Avatar
privateer, eh
I've got the cheap Astro Pneumatic Tool co. kit to remove ball joints. First thing I did was to take a grease brush and greased the bolt to remove any resistance. Have used it a half dozen times in last 3 years, worked on my 89 f350 dually ball joints. I'm the guy who sprays and wire brushes anything rusty before I put a tool to it, also have a large selection of hammers to chose from. Cheap tools work if your easy on them, it's a pita sometimes but poor boy is broke boy not broken tool boy.
Lstanley
15
Feb 15, 2011 06:22 AM
rbsample
35
Dec 10, 2010 06:55 PM
CarlF250
Mar 13, 2008 02:25 PM
riley42204
Apr 4, 2006 09:53 PM
Gunpowderboy
1978 - 1996 Big Bronco
Dec 3, 2004 03:24 PM
