Need Help, Multiple Problems
Old Sep 27, 2015 | 12:19 PM
Punishment23's Avatar
Punishment23
Yes. Most of them are connected to something and then are just open and some are capped with a screw or bolt. Ill start doing them one at a time. Im about to haul some wood. So Ill start posting pics maybe later today or tomorrow and go one by one. I thank you guys so much for the help. I just want a dependable work truck
Old Sep 27, 2015 | 12:23 PM
tjc transport's Avatar
tjc transport
i ain't rite
my 04 had a 1/16 inch vacuum line with a pinhole in it. that was enough to give me a miss at idle and throw a check engine light.
it took me close to 3 months to find it.
Old Sep 27, 2015 | 12:56 PM
Plowboy34's Avatar
Plowboy34
First on the losing water, your radiator cap could be bad and not holding pressure on the system and allow a little water to boil away all the time.
Second a 87 460 should have an electrical fuel pump. I have a good friend who has an 86 with a 460 with electric fuel pump in tank and it's carbed and I believe 87 is when the 460 went EFI, now I was in California at that time so they may have got it a year earlier as they sometimes do.
Old Sep 27, 2015 | 01:12 PM
Punishment23
Brand new radiator cap, hose clamps, thermostat, and thermostat gasket. So I don't think that's it. Like literally I've looked at everything, all that's left has to be head gasket. All I can think of. Ill run a block test next week and well see. Mine is def carbed. Ill switch to holley later with a 750. But Ill keep the eddy 600 for as long as possible
I'm pretty sure its electric. So when I get more funds Ill go over all the lines and replace the hose clamps and rubber hoses.
SomeDude451
Jan 26, 2016 07:16 PM
frdlvr35
Apr 6, 2011 08:24 PM
mellowfe
Feb 23, 2011 05:56 AM
Dlobacz
Feb 16, 2008 08:15 PM
DouginTahoe
Apr 5, 2005 07:52 PM
