replacing fuel pump
Old Sep 26, 2015 | 01:24 PM
markeyd's Avatar
markeyd
replacing fuel pump
Replacing the fuel pump on a 66 f-100 that has a 390 from a 1975 f-250.
The old pump has a threaded fitting and the new pump has those slip on and clamp type fittings.
The old pump has a metal tube running from the threaded fitting to a short rubber hose at the carb.
Is it OK to replace that metal tube with a rubber fuel hose? Is there a reason to have a metal tube, or since a hose will fit, can I just use a hose? There are a few bends in the tube so I am also wondering if rubber fuel hose will collapse in on itself and restrict the flow of fuel or are they designed to prevent that assuming no sharp angles?
Thanks in advance
Old Sep 26, 2015 | 05:22 PM
KO1960's Avatar
KO1960
I would keep the hard line and adapt it to the new pump. Will the slip on fitting unscrew from the pump? If so, you may be able to attach the hard line. Keep the rubber fuel hose to a minimum.
Old Sep 26, 2015 | 08:14 PM
Tedster9's Avatar
Tedster9
I would agree with avoiding the use of rubber hose.
Auto parts stores sell the greenish colored ni-cop 3/8ths or 5/16ths hard metal brake line/fuel line in different lengths that bends up pretty easy. If you ask for actual fuel line they are liable to give you the blank stare or say they don't sell it.
Old Sep 27, 2015 | 07:20 AM
markeyd's Avatar
markeyd
Thank you.
seventhfire
Aug 31, 2018 09:30 PM
78ford400cid
Aug 11, 2018 02:41 PM
Orangeford74
Aug 28, 2016 01:39 PM
dino12gauge
Jun 27, 2007 10:14 PM
