Psd Fuel line quick connect
Old Jun 27, 2007 | 09:44 PM
dino12gauge's Avatar
dino12gauge
I have a diesel Excursion.How does the quick connect go back on the fuel pump? I did look real close when taking off. But the plastic deal goes on then the o-ring then the hose right? Just can't get the thing go on right.
Old Jun 27, 2007 | 10:14 PM
F250_'s Avatar
F250_
If you're putting it on the suction side of the pump, try to simply cut off the quick connect adn hose clamp the hose to the pump's intake nipple (will need to heat up the hose first with a hair dryer so that it will slip over the bulge in the nipple). Those quick connects are great under pressure, but really suck when under vacuum - and I mean that they REALLY suck AIR into the fuel line.
