400+hp questions
Old May 17, 2016 | 08:00 AM
Tugly's Avatar
Tugly
Overrboost Code Regulator [LINK]
Many chips don't need this to prevent an overboost code - but the MAP sensor has a physical pressure limit before you overdo it. The MAX boost is just shy of 35 PSI before the MAP sensor has an issue, and 400 HP with a proper turbo will pop that.
Old May 17, 2016 | 12:20 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
Originally Posted by cookie88
I wish "kits" like that were around 14 years ago.
Cookie88... Whaddya tawkin about? The Kim Lux Kit was around 15 years ago! (I wonder whatever happened to him. I wonder if anyone is still waiting for their kit.)
Rippenbass... Unexplained acronyms kill me too. I've been around Ford diesels for more than 20 years, and I never heard of the acronym "OCR" until today.
TJBradney... congrats on getting married! That life event alone would cause me to seriously question how much dough I was dumping under the hood.
But separate and apart from that, I have another much smaller question: You only have 130K miles on your Ex... and you are already having to replace injectors? Why?
Are the plungers and barrels and solenoids of your injectors really that worn out? Or do you just need new O-rings? Or is this purely a power play?
And, the injectors listed in your sig are already Swamp 200cc/30%. So are the new injectors actually your second set of Swamp 200/30s? Making this really the third set of injectors (counting the OEM ones) in only 130K miles?
Something doesn't seem right with that short of life. I would expect a decent set of HEUI injectors to last 200K.
Old May 17, 2016 | 12:33 PM
scsjones's Avatar
scsjones
posting a thread
can someone help me out? i have no clue how to post a new thread. can someone clear this up??
Old May 17, 2016 | 12:34 PM
Rikster-7700's Avatar
Rikster-7700
When on the main page there is a button that says new thread?
Old May 17, 2016 | 12:39 PM
HKusp's Avatar
HKusp
Thread was started in September of 2015, so he probably updated his signature when he got it done.
Old May 18, 2016 | 07:26 PM
Rippinbass's Avatar
Rippinbass
Thank you.
JJ1101
Nov 29, 2018 05:42 PM
GSlahor
Apr 17, 2017 02:01 PM
Resendiz
Nov 12, 2015 06:58 AM
Tim Young
Aug 1, 2009 03:06 PM
jleal_21
Mar 6, 2009 09:01 PM
