Engine cut off 55 mph .
Old Sep 25, 2015 | 02:44 PM
Shu's Avatar
Shu
New from VA. , first post . The other day I had been driving about 3 hours and truck went dead then back on ,it happened two more times in about 30 minutes. ( 2001 F 350 Dually 7.3 A/T 2 wd.) . Any ideas ? Thanks ....... Shu
Old Sep 25, 2015 | 03:27 PM
scotttahoe's Avatar
scotttahoe
That is your CPS sensor failing.
Pass side under the water pump.
Old Sep 25, 2015 | 03:47 PM
Shu's Avatar
Shu
Thanks scottahoe I'll replace it this weekend.
Old Sep 25, 2015 | 03:50 PM
scotttahoe's Avatar
scotttahoe
You really need to go OEM on the sensor. If you go after market it won't last and believe it or not when you run your wipers it will cut out the motor as well.
Here is a good source.
Motorcraft Cam Position Sensor CPS 94.5-03 - Riffraff Diesel Performance
Old Sep 26, 2015 | 11:19 AM
Shu's Avatar
Shu
Thanks scottahoe for info. and source, and it was raining both times when it happened wipers on low. I checked with previous owner and he used napa brand.
dmiasin
26
Dec 2, 2020 10:21 AM
blm250
Sep 16, 2013 05:47 PM
cvcoleman56
Apr 4, 2012 07:14 AM
SPELLY F150
May 5, 2006 06:21 PM
AnchorageAk.PSD
Jul 8, 2005 08:42 AM
