After doing all the brakes and rear trailing arms I just found out what's causing loud clunking noise when going over bumps - right lower control arm is bad and needs to be replaced. I had lower ball joints replaced a few years ago but now the actual control arm is bad.
How hard of a job is it to get that control arm replaced? The guy at the shop said it's a real pain with torsion bars. Just trying to figure out if that is something I want to try and do myself or have the mechanic do it.
Thank you
Don't know what I would do without this forum....you guys are great
