Turn signals quit working
Old Sep 21, 2015 | 01:59 AM
Old Brown Truck's Avatar
Old Brown Truck
Last winter, I had the turn signals in my 76 F100 quit working. I ordered a replacement turn signal switch and also swapped out the auto shift column for a no shifter column (I have a 4 speed now). I got it together where the turn signals were working, the Emergency flashers worked and the horn worked when I provided a jumper across the rag joint. The wires were a bit sketchy though, very thin insulation.
A few months later, the turn signals quit working again.
Today I replaced the turn signal switch with a better looking switch from Car Quest. The emergency flashers all work, and the horn works (with the jumper across the rag joint) But the Signals still don't work.
I swapped out the flasher unit for the turn signals from my 79. Both flashers work in the 79, neither work in the 76.
I can't figure out which fuse in the fuse block provide power for the turn signals.
While I was trying to figure out the fuse box, I found that the 7.5A short fuse is a unicorn in 4 places I shopped today. As near as I can tell the Top slot labeled: St. BLT. is for the Seat Belt Buzzer, which I can do without. I do need a 7.5 shorty for my Radio though.
What does Eng Sol do? power to the starter solenoid?
Any idea which fuse if for the turn signals, and also where to get 7.5A short fuses?
Old Sep 21, 2015 | 07:31 AM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
https://www.ford-trucks.com/forums/1...l#post14696846
1st page post #10 has a fuse diagram for you.
Bottom row of fuse block, 2nd from left is the t/s one.
Old Sep 21, 2015 | 01:00 PM
Old Brown Truck
My Fuse box doesn't match your diagram. I did find a diagram on line for a 76 specifically that does but doesn't label a slot for Turn Signals.
Old Sep 21, 2015 | 06:22 PM
Old Brown Truck
PROBLEM SOLVED!
I discovered that the B/U 15A fuse was blown. When I replaced it, the Turn Signals and the Backup lights work as normal.
My fuse box has the same number of slots with the same lengths, but is labeled differently than the diagram posted here.
Differences:
On mine, #1 isn't empty instead it's labeled 30A Heater
#3 isn't Heater it's 7.5A Aux Fuel (never has had dual tanks)
#6 isn't Dual Tank Solenoid it's Empty
#9 isn't Turn Signals it's Empty
Old Sep 22, 2015 | 02:46 AM
burnthelight88's Avatar
burnthelight88
I'm seriously looking to replace my fuse block with blade fuses without rewiring the whole truck. I've been putting off the full rewire because I'm not having any problem, but these fuses are hard as heck to come by.
Old Sep 23, 2015 | 08:47 AM
bkaul's Avatar
bkaul
Any auto parts store should sell them. Or order online from Amazon or some such place.
Nothing wrong with switching to blade fuses if you like, but I can't see how the glass ones should be hard to come by.
Old Sep 26, 2015 | 11:46 PM
Old Brown Truck
I'm suppose to have a 7.5 Amp fuse for my radio (same length as the 15a B/U fuse) I'm unclear as to the labels such as AGX and AGW... It looks like it has to do with length. In any case I raided my 79 for the radio fuse because I couldn't find an AGX 7.5 at CarQuest, AutoZone, O'Reileys or Frys. I did a search on line and only found 7A AGXs (not 7.5)
Is there a list of the proper fuse types... and a suggested vendor?
BTW... the B/U - Turn Signal fuse kept blowing. I disconnected the B/U light switch at the transmission, and since then, I've not blown the fuse. I guess I need to begin tracing the B/U light circuit. The fuse doesn't blow immediately, but maybe after 30 min.
Oh yeah and after getting the dash lights working with new LEDs and getting the turn signals straightened out, my starter decided to break. Got that replaced this afternoon.
One issue I'm having with the steering wheel after having replaced the column and turn signal switch, is that it groans a lot especially turning right. I don't mean groaning from the steering pump, I mean like a friction thing. I'm thinking I need to use some kind of Vaseline or Di-electric grease where the horn contact rubs on the steering wheel contact. The ball bearing bushing looked fine and rotates freely?
cdat81986
18
Sep 14, 2022 08:02 AM
JohnBOV43159
Aug 5, 2018 07:59 AM
hayden01
Electrical Systems/Wiring
15
Oct 25, 2017 05:39 PM
KingProvince
Apr 13, 2017 10:33 PM
E30tdf
May 17, 2014 12:55 AM
