fuel gauge
Old Sep 20, 2015 | 08:05 PM
87ford1997's Avatar
87ford1997
fuel gauge
hey i just recently bought a 1987 ford f150 it has the EFI 302 automatic with 84503 miles on it. and the fuel gauge sits on full when the truck is off and then moves further past full when the truck is turned on. what causes this and how do i fix it?
Old Sep 20, 2015 | 08:24 PM
Cruiseomatic's Avatar
Cruiseomatic
Check your grounds. Is it dual or single tanks? My '87 pegs past full when switched to front tank and I think i have a bad ground with infinite resistance.
Old Sep 20, 2015 | 08:28 PM
87ford1997's Avatar
87ford1997
its dual tanks but the rear tank has been removed and just the front tank remains. and where would my grounds be located at?
Old Sep 20, 2015 | 08:34 PM
Cruiseomatic
Really, It could be bad grounds or sending unit. Check your grounds at the tank, selector switch, and at the valve on the rail. You might need to drop the tank and manually move the sending unit float. After 20+ years, things do get dirty and need attention.
Old Sep 20, 2015 | 08:43 PM
87ford1997's Avatar
87ford1997
Ill get under there tomorrow and check the grounds. now the valve on the rail? can you explain to me where that is located and what it looks like?
Old Sep 20, 2015 | 09:58 PM
87ford1997's Avatar
87ford1997
like i know you said itis on the rail but ware abouts on it.. towards the front back middle..i was under there the other day and seen nothing that looked like a valve..thats why i asked.
Old Sep 20, 2015 | 10:03 PM
Cruiseomatic
It will be on the rail either directly infront or next to the front tank. It will have a harness connected to it.
Old Sep 20, 2015 | 11:29 PM
88XLTLariat's Avatar
88XLTLariat
Look on the drivers side rail, just aft of the door.
Old Sep 21, 2015 | 12:40 PM
87ford1997's Avatar
87ford1997
okay so I think I found the valve but cant seem to find the ground wire. is there a particular color of wire that I am looking for? and how do I test it to make sure its grounded right?
90'F150
Jun 12, 2013 09:16 PM
Pete Roberts
Feb 24, 2011 07:29 PM
John B
Feb 2, 2005 07:30 PM
samfissure
May 5, 2004 12:32 AM
Rbuller24
15
Jun 11, 2003 06:29 PM
