Big Ed (1970'71 F250) constantly overheats. Radiator has been changed, thermostat changed. Haters tell me it's typical of a Ford. Any comments or ideas? I use this truck for firewood, hauling ......
A few ideas of things to look at and check. First off, make sure you have the thermostat installed correctly. Don't like to admit it but I installed it in the wrong direction and it is very easy to do on these FE's. Second, has the block been flushed out? These old motors can accumulate a lot of stuff in the block and need to be flushed out...sounds like everything else is newer and working so this could be it. Third, do you have a fan shroud and how close to the radiator is the fan? These FE's make a lot of heat and there's not a lot of air moving at idle speed and those two things can affect it a lot.
Lastly, how's your oil pressure?
Good luck.
Does it have a fan shroud? Perhaps air trapped in system?
Or engines' coolant passages are full of crud and has never been properly flushed. If equipped with an FE, gotta pull the two pipe plugs low on the block below cylinders 3 and 7. If nothing comes out, poke it and keep clear or else you'll be wearing it.
Other than that, timing is out of spec or the engine is on its last legs...
A friend of mine suggests throwing a few of those dishwasher detergent pellets into your radiator and running it a bit and then flushing. They have stuff that is good at breaking down the grit and stuff that forms.
The most common problem of over heating is a lack of proper cooling system maintenance. Other things possible vacuum advance leak sucking air making it run lean. if running a fan clutch fan clutch needs replacing or not correct size pulley, pulley is for a manual fan to large= water pump turning to slow to keep it cool.
Need more input we can't play the guessing game.
Orich
When the system is working properly, and moving forward 20 mph or more no fan or shroud is needed. Sitting idling is another thing, in the summer time it will not do for more than a few minutes.
Is your system puking cooklant? The coolant needs to be about 3in down for expansion. As long as you can see coolant on a cold rest you are OK.
2X is this recent or ongoing? If recent what happened or what was changed just before it started overheating? A real good flush would be a really good idea. Timing or dwell off? Vacuum leak?
