intermittent overheating
Old May 3, 2002 | 10:15 PM
WrenchHead84's Avatar
WrenchHead84
Post intermittent overheating
On my '79 F-150 with a 302, I get an intermittent overheating problem from different ranges of outside temperatures. The thermostat has been replaced, the coolant is good, and the oil has been recently changed. Any ideas what would cause this to happen? I'm tired of running the heater every now and then when it's 70 degrees out.
Thanks for any help
WrenchHead
1979 F-150 Custom. 302 V-8 4-spd 2WD. 122,875 Miles
Old May 3, 2002 | 10:20 PM
trinogt's Avatar
trinogt
It took me a newer radiator from the wrecking yard to cure that problem. It was corroded up inside and plugged up passages. Hard to see anything wrong, but that cured it. I had already done the flushes, new water pump, thermostat, etc.
Mark
>Thanks for any help
>WrenchHead
Old May 3, 2002 | 10:45 PM
Fatrap's Avatar
Fatrap
I'd check two easy things before removing your radiator. First, replace you radiator cap. It's not just a cap, it's an important part of the system in maintaining correct pressure, which means correct cooling.
Secondly, I'd test the thermostat. About 6 years ago I replaced the thermostat in my Corolla with a brand new one. Well, the new one was no good. You can test yours on the stove top in hot water.
If you had an electric fan, I'd tell you to also check the relay. Oh well.
Intermittant over-heating is always caused by bad circulation of some type. Most often, a malfunctioning thermostat. It could also be that your block is dirty. Over the years, antifreeze puts silica sand in your block. Have you flushed your block lately?? I don't mean through the radiator, I mean through the block drain plug.
Old May 3, 2002 | 11:05 PM
TheWiz427's Avatar
TheWiz427
Might want to check the fan clutch to?
Old May 5, 2002 | 05:53 PM
ford_nut's Avatar
ford_nut
Old May 6, 2002 | 12:06 PM
beartracks's Avatar
beartracks
Check the sender unit and wires to make sure you get an accurate reading.
Bear
Old May 6, 2002 | 04:07 PM
dfisher1's Avatar
dfisher1
Wrench,
It's not your thermostat.
It's not your automatic tranny; you've got a 4speed.
Is it your fan. There is no fan clutch on your truck.
I'm afraid it's your radiator. I have often said the best investment you can make in your truck after changing the oil is a strong radiator. Get it boiled and brushed for about $40 and you'll be good to go.
My Way is the Highway,
KingFisher
wrenchhead428
18
May 26, 2015 01:24 PM
wrenchhead427
Mar 27, 2007 02:23 PM
WrenchHead84
May 5, 2002 04:15 PM
WrenchHead84
Jul 19, 2001 07:38 AM
WrenchHead84
Jul 15, 2001 02:00 AM
