Back up camera suggestion??
Old Sep 17, 2015 | 07:51 PM
vanthony's Avatar
vanthony
It really makes me nervous backing this big rig up, so, I am really considering getting a backup camera, which I guess will result in getting a double din head unit, since I don't want a separate monitor mounted on the dash. Any suggestions? Pros? Cons?
Old Sep 17, 2015 | 09:14 PM
Matt M, PA's Avatar
Matt M, PA
I used a Kenwood camera mounted just under the double doors...but above the bumper. I used a rear view mirror made by MITO that has the monitor/screen inside. The picture comes on when I switch into reverse.
Old Sep 17, 2015 | 11:11 PM
vanthony's Avatar
vanthony
That's a thought.
Old Sep 18, 2015 | 12:24 AM
Kalabin's Avatar
Kalabin
I just installed a Kenwood DDX672 head unit along with a license plate back up camera made by Esky EC170-09 off of Amazon (30 bucks). The camera was the easy part of the install, modifying your dash will make you question it a bit. For the "Dash Kit" to fit properly I had to Dremel out the entire lip around all four corners. Most of the installs show only removing the top / bottom. However with the Dash kit it looks very clean.
Just make sure you buy the following parts to help speed up the install and make it look clean.
Metra 95-5817 Dash Kit
Metra 70-1771 Receiver Wiring Harness
Metra 86-5618 Factory Radio Removal Tools
I tapped power into the license plate via the rear left back up light. That way whenever I go into reverse the camera kicks on just like the newer OEM back up cameras. It works great for my use, and has made lining up my hitch a lot better.
You can go with a custom install back up camera as some guys have, but for the price and ease of install I highly recommend it.
Old Sep 18, 2015 | 01:16 AM
vanthony's Avatar
vanthony
That's a nice looking camera. Thanks for the tip.
Old Sep 18, 2015 | 02:51 AM
pirate4x4_camo's Avatar
pirate4x4_camo
My pioneer HU is a few years old and doesn't have the green, yellow, red parking aid lines on the screen, I saw them when the new high end models were released and it didn't seem worth the $ consider what I spent on mine, Then I drove a friends new ford with the factor back up aid... I wouldn't buy a system now with out it.. They are pretty slick.
I also us the license plate frame camera.
I went to a audio store to look at some new gear But they didn't have what I want. However they did have some sweet dash cams which got me thinking... Next head unit will have a dash cam and DVR capabilities.
Old Sep 18, 2015 | 04:21 AM
cameeks's Avatar
cameeks
Most radios have a wire that hooks to the reverse in the truck to sense when you put it in reverse. I wired my camera to a hot wire in the 7 way trailer plug so I can turn on the camera at the head unit when ever I want and it still comes on when I put it in reverse automatically. It's good for checking on short trailers when your going down the road. I just regret mounting the camera right beside the license plate. The license plate light kills the night vision by shining on it.
Old Sep 18, 2015 | 09:08 AM
A Rodder's Avatar
A Rodder
If you don't need a new stereo, consider the edge evolution cts programmer or the insight cts which is only a monitor.
They have inputs for video.
I use a license plate camera setup fed into mine. Has additional led lights and will turn on automatically or via switch anytime I want.
You may not like the additional monitor piece but it provided lots of information, some crucial information.
Old Sep 18, 2015 | 10:00 AM
devovino's Avatar
devovino
I was seeing that you were going to possibly go with a Android head unit, they will do this as well, some of the ones I have seen on E-Bay also include a B/U camera with them. Go ahead and spearhead this project, so I can follow suit, let me know how it goes...
Old Sep 18, 2015 | 11:36 AM
vanthony's Avatar
vanthony
Yes, I am considering both. Just looking for the best options before spending the money.
Old Sep 18, 2015 | 12:50 PM
Magnus E's Avatar
Magnus E
App-Tronics SmartVision Mirror Replacement mirror with dash cam, rear-view camera, and Bluetooth® at Crutchfield.com
I've been thinking about putting in one of these smart mirrors
Old Sep 18, 2015 | 01:37 PM
Alex F's Avatar
Alex F
Is it possible to mount a camera above the back doors in the material next to the third row light?
I think that would be a great place considering I do tow at times, and I'd be able to see partially around the boat/jetskis/etc.
Old Sep 18, 2015 | 02:06 PM
Turfzilla's Avatar
Turfzilla
Google bluetooth camera if you want a temporary set up. There are several cheap options that I considered. I was just wanting something simple for my infrequent trailer hook-up and not deal with wiring something up and having a monitor in my way all the time. I have not bought one yet, just wanted to share another possible option for you.
Diesel_dans_psd
Aug 6, 2019 07:36 AM
berry1234
2004 - 2008 F150
Nov 3, 2013 09:21 PM
BillyBob69
Apr 8, 2007 10:57 AM
BillyBob69
Apr 4, 2007 12:46 PM
