Starter problem
Old Sep 16, 2015 | 07:29 PM
Sawyerjosh's Avatar
Sawyerjosh
Starter problem
I have a 1978 F150 that I use for a plow truck. Recently the starter stopped working. The positive wire was worn so I replaced it, along with the ground wire to the batter and the starter. I was still getting nothing. Tonight I replaced the cab mounted solenoid. As soon as I connected the batter the starter engaged, even with the key out of the ignition. I am not much of a mechanic and am wondering if I should be suspecting that the new solenoid is bad or could there be something in the ignition? Not sure how to test it other than another new solenoid. Any help is greatly appreciated!
Old Sep 16, 2015 | 07:52 PM
Jkenosh's Avatar
Jkenosh
I have seen that when you are not using the correct solenoid or if you have the two little wires crossed. I would unplug them and test them with a test light I think the one towards the front of the truck is the ignition but I ain't sure
Old Sep 16, 2015 | 08:10 PM
Sawyerjosh's Avatar
Sawyerjosh
I pulled both of them off and it still did it. I know it's the correct solenoid but thinking it may be bad right off the bat.
Old Sep 16, 2015 | 08:22 PM
Jkenosh's Avatar
Jkenosh
If both are off than it is bad. Can bang on it to get plunger unstuck but I would replace it
Old Sep 16, 2015 | 08:23 PM
Jkenosh's Avatar
Jkenosh
Or you got the starter wire on the wrong side. Should be on the side toward the cab. Not on the front side with the positive cable
Old Sep 16, 2015 | 10:34 PM
Willz74's Avatar
Willz74
pull the starter wire off touch the positive to the battery and make that the only wire going to it if you don't hear a click you might be able to hit it with a wrench and fix it if there is a click it's an internal short and isn't fixable
Old Sep 17, 2015 | 11:22 AM
Sawyerjosh's Avatar
Sawyerjosh
Thanks! The new solenoid was indeed the problem. Got a new new one today and she fired right up. Appreciate it!
tassmannn
1978 - 1996 Big Bronco
Mar 3, 2016 08:18 AM
GIFord
16
Sep 26, 2012 07:05 AM
RVF150
Jun 26, 2012 03:09 PM
rwk26164
1997 - 2003 F150
Dec 24, 2011 03:35 PM
Holiver31
Mar 9, 2011 09:18 PM
