Bronco II Ford Bronco II
Idle problem '89
Old Sep 15, 2015 | 08:47 PM
Jabaker09's Avatar
Jabaker09
Idle problem '89
I have a bronco ii and just installed a new battery and in line fuel filter Bc the truck started to die on me just when driving. Now it won't even idle but for a few seconds then it dies. Idk what to check. Any suggestions or someone had the same problem before?
Old Sep 15, 2015 | 08:52 PM
Tedster9's Avatar
Tedster9
Welcome to FTE!
Keep that new battery topped off with a charger while things get sorted out.
Old Sep 15, 2015 | 08:58 PM
Jabaker09's Avatar
Jabaker09
Thanks man I will
Old Sep 24, 2015 | 10:55 AM
SamiO's Avatar
SamiO
If it just happened after installing the inline fuel filter, I'd suggest checking you installed it correctly. I don't know if fuel will flow at all when it's installed backwards, but it has a directional arrow on the side of the filter, which should point towards the front of the vehicle. Like this:
Copedawg
30
Jun 26, 2011 01:30 PM
Suber
46
Aug 6, 2007 02:47 PM
f150plow
Nov 24, 2006 12:18 PM
desperado_18_2000
May 19, 2002 11:35 AM
