Vent Window Lower Pivot Pin Replacement
Old Sep 14, 2015 | 12:00 PM
_Chuck_'s Avatar
_Chuck_
Does anyone know where I can pick up a vent window lower pivot pin for a '52 F1? My vent windows and all components are in good shape, except the upper pivot cup is broken and the lower pivot pin is sheared off. I have found sources online for the upper pivot cup and the vent window frame without pivots, but no lower pivot pin.
Is it possible that the lower pivot pin for 1953/55 would work? I noticed that Oscar, Kurt and Ilya have posted a few times on this topic, but I did not see that they commented on a source for this lower pivot pin.
If not a pivot pin are there any full frames (driver's side) with pivots that someone is open to parting with?
Also, can anyone confirm that I will need to remove all the door glass and division bar to replace the pivots? Would that also require replacing anything else, like the seal?
Here are some reference images:
1953/55 from the Ford Parts Catalog
1948/52 from LMC Catalog
1953/55 from LMC Catalog
Old Sep 14, 2015 | 01:32 PM
JPMallory's Avatar
JPMallory
No one makes the lower pivot that I know of. When I broke one, I ended up buying the whole vent window assmbly offf ebay to replace it.
Old Sep 14, 2015 | 02:08 PM
gerrymoe's Avatar
gerrymoe
I would look at mid-fifties part # 1147 Left or right and see if they could be adapted.
Search Results - Mid Fifty F-100 Parts
Old Sep 15, 2015 | 05:52 PM
oscajo's Avatar
oscajo
I`m using the ones from mid fifty
and they seem to be working fine. my biggest problem is the vent window rubber seems too stiff and makes closing my windows very very tight. If I already had AC I would have went with the single side window kit.
mgargiullo
Sep 12, 2019 10:30 PM
bstephen33
'80-'86 FAQs (Frequently Asked Questions)
Apr 5, 2019 01:12 PM
Ffbrass
Oct 12, 2018 04:20 PM
ct50f1
May 3, 2017 06:28 PM
bstephen33
Jan 20, 2011 12:07 PM
