Gettin' ready to pull her out
Old Sep 12, 2015 | 04:45 PM
Per4mance's Avatar
Per4mance
OK,I've had a really bad couple of weeks and got NOTHING done on my truck. I went and talked with my friend Kenny today and he said I could use his shop in a couple of weeks as he didn't want to see me working on my driveway breaking my *** for no reason, but, there is a catch,I have to help him with a 03 that's coming in first for a full bullet job, so I agreed. Tomorrow I'm going to make ready all the bolts for the cab lift and take out all the non functional stuff to steer it and brake it so that will be all that's left when I get it there and we can pop it off in record time. I though about some extensive mods for horse power and tork but common sense prevailed.I will be putting a 6.7 fuel pump in and a regulated return thou,new lifters and all the newst oring mods and gaskets. I'm going to make myself the ginnie pig for Fel Pro head gaskets and ARP studs. EGR delete by IPR and some custom tunes on the FICM and Livewire.......Which reminds me I got to get mine to Ed so I have it for reassembly. I haven't decided which return to use yet but I'm open for ideas.......
Old Sep 12, 2015 | 06:46 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
It's nice to have good friends! Subscribing....
Sounds like a good plan and looking forward to hearing about your progress. Take your time and have fun!
Old Sep 12, 2015 | 07:22 PM
KDAVID1's Avatar
KDAVID1
Glad to see you finally getting to it.
Old Sep 12, 2015 | 08:53 PM
Maxium4x4's Avatar
Maxium4x4
Head gaskets (Ford/IH) are not a problem unless you are receiving the Fel Pro's for free... other than that sounds like a project.
Old Sep 12, 2015 | 09:06 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Take pics, give Anthony and Snowseeker (Andy?)'s threads a run for their money with all the truck **** you can provide
Old Sep 13, 2015 | 05:46 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
That is a VERY fair trade that I'd be chomping at the bit for!
Glad to hear your truck will be back on the road soon!
Old Nov 1, 2015 | 03:36 PM
Per4mance's Avatar
Per4mance
OK, just got done taking inventory on the parts for this job. I know I'm forgetting some thing. Headstuds, gaskets, IPR delete for EGR, orings for injectors and rails, rear plate, ELC antifreeze, new Ford oil cooler, turbo kit, and FICM is going out to Ed when I get it out.......feel free to chime in
Old Nov 1, 2015 | 04:46 PM
KDAVID1's Avatar
KDAVID1
Don't forget intake gaskets, fuel line orings and crush washers, pcv oring, intake to front cover donut oring, oil filter stand pipe gasket and adaper oring (if you take it apart).
Old Nov 1, 2015 | 05:34 PM
Shaneb75's Avatar
Shaneb75
Strokin Okie
Lifters, push rods, standpipes, dummy plugs, front and rear cover seals, oil pan gasket, rocker box gaskets, valve cover gaskets, glow plugs/harnesses, upper/lower radiator hoses, drive belt OH and the NEW STC fitting...
That should keep you busy and broke for a bit.
Old Nov 1, 2015 | 05:57 PM
Macrosill's Avatar
Macrosill
x2 on the intake to front cover donut oring
I got stuck and had to buy a whole oring kit from a dealer to get the, uhm, oring I needed!
Maxium4x4's Avatar
Maxium4x4
They do have an upper kit with everything but it includes head gaskets and paper weights .. torque to yield bolts...
Old Nov 1, 2015 | 06:08 PM
Per4mance's Avatar
Per4mance
Got SCT fitting ,standpipes and dummy plugs. Orings on the way, I forgot to mention I got to get a front cover as the waterpump housing where the pump sits is scored from a bad waterpump bearing problems.
Mowing Man
47
Dec 8, 2013 07:18 AM
Larzon
May 19, 2013 12:13 AM
davbeisner
Aug 30, 2012 05:39 AM
wulfman
Jul 14, 2012 08:02 AM
skirk55
Delaware Chapter
Nov 22, 2010 07:46 PM
