Wiper vacuum
Old Jul 17, 2011 | 12:51 AM
tiger_698's Avatar
tiger_698
Question Wiper vacuum
I have been knocking out my to do list on my truck. One of them is to run a line to the vacuum. I decided to check to make sure it works before splicing a line for it. I ran a hose to the wiper motor and turned it on. All I hear is the sucking noise; no wiper movement at all. I have never been in a car with a vacuum motor, so I'm not sure if the sucking is supposed to be there. I do not think it is coming from the line itself. It took a lot of work to get the hose onto the port. But I do not know exactly where the noise is coming from. Can someone help me trouble shoot my problem?
....or make me feel stupid by telling me a simple mistake I am making on it!
Old Jul 17, 2011 | 08:40 AM
r_reed's Avatar
r_reed
i know that when i was trying to rehab mine, i googled vacuum wiper motor, etc. and found some good instructions on rehabbing them. if the seal inside is leather, it might just need soaking (wd 40?? don't rem for sure) if it's rubber i guess it's a lost cause? got mine to work weakly but wouldn't push two wipers, so went electric. others with more knowledge should be along shortly.
Old Jul 17, 2011 | 11:27 AM
GreatNorthWoods's Avatar
GreatNorthWoods
The wiper should move when vacuum is applied to it. The wiper motor probably needs rebuilding or maybe you can pick up another one on Ebay...
Old Jul 17, 2011 | 01:55 PM
52 Merc's Avatar
52 Merc
This may sound stupid, but did you hook up the vacuum line to the correct port? There is an exhaust tube that looks just like the fitting the vacuum line is supposed to go on.
Old Jul 17, 2011 | 02:46 PM
tiger_698's Avatar
tiger_698
Merc, not a stupid question at all. I originally just hooked it up to the only one I could see. Later I went back and looked in more detail to see the other. Neither side being hooked up will move the wiper.
I plan to convert over to electric, I just wanted to wait a while before doing so. I've spent a lot trying to get it running this year. I was hoping that a few feet of vacuum hose and a couple fittings would fix my problem. I guess I'll be buying a new kit sooner than planned.
Anyone bought one of these kits from Dennis Carpenter? Like or dislike it? http://www.parts123.com/parts123/yb....5Z5Z50000024C#
Old Jul 18, 2011 | 07:26 AM
Baxtjh's Avatar
Baxtjh
Vacuum wiper repair
I attempted to rebuild the vacuum motor on my '53 but could not replace the rubber flapper.
I sent it out to Fricken Wiper Repair. $99 plus shipping and it works fine.
WiperMan.COM - Wipers, Wipers, Wipers
On mine, there is a connection at the top for the vacuum hose. There is also a port at the bottom out of which I do hear air.
Best wishes.
Grits
ArlyDude
Dec 14, 2014 09:32 PM
JPMallory
Mar 29, 2014 01:58 PM
mackda600
Mar 27, 2014 10:32 PM
brider
Apr 11, 2007 08:32 AM
Wakeboarder141
1978 - 1996 Big Bronco
Oct 1, 2003 12:28 AM
