Ok guys so when the truck is off the fuel needle stays on full instead of dropping but when started it goes to the needle stopper past full. Is this a float problem or something similar and how can it be fixed?
its a ground issue, or bad senders.
if it was a power problem it wouldnt read at all.
another thing it could be is the FSV.
(fuel switch valve)
both tanks in my 91 reaf full just like you said,
i changed the FSV, and it fixed the issue,
but my rear tank wouldnt function too, this is why i changed the FSV.
the OEM units run just about 275.
