I bought a 99 F250 Super Duty with a 5.4 the other day for cheap. The only problem is someone did an engine swap on it and made a shade tree mechanic look like nuclear engineer!!!
I went ahead and pulled the engine out and transmission to go through it and replace the timing components, oil pump, all the seals, and the clutch.
Before I started the vacuum lines were all over the place and not hooked up properly and were not oem hoses on half and there were double of some things... JUST A NIGHTMARE!!! I figured out the dpfe hoses and the evap hoses already...
What I need is to know what goes to the two intake tube ports? One is the IAC if I remember??
