Help please!!
Old Sep 9, 2015 | 04:45 PM
jmuenchow's Avatar
jmuenchow
Help please!!
my 91 7.3 with e4od started shifting terrible over night to the point where it jerks the entire truck. I thought it may be the tps but I adjusted it last night to 1.2 v idle and it still jerks hard. It seems to be slipping. It won't shift out of first until ~21 mph. The harness on the passenger side of the tranny behind the heat shield is free from corrosion and debris. Tps harness is ok along with rpm sensor harness. My tach and speedometer work fine and my od light doesn't blink at all. I also replaced my eec (?) relay and that didn't fix it. My fluid is ok. But I don't know how to get codes from the truck. If someone can guide me through that it would be awesome. WHAT COULD THIS BE?!?!
Old Sep 9, 2015 | 05:32 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
First thing I would do is disconnect the batteries for about five minutes and then reconnect them. If it solves the problem, you were in limp mode. If it goes back into limp mode, get a scanner and read your codes. A scanner isn't too much, and anyone with an E40D should have one.
Old Sep 9, 2015 | 09:54 PM
jmuenchow's Avatar
jmuenchow
I disconnected the batteries and it fixed it somewhat. Shifts much better except from 1->2. Not as bad as before. I'm thinking this could be adjusted by the TPS? Am I correct?
Old Sep 10, 2015 | 12:20 AM
akamacgyver
Clueless spectator!
Does it still shift hard, or just at the wrong rpm's? It could be your FIPL (TPS). IIRC you want 1.4 at idle and 4.3 at wot. I had to play with mine to get it just right.
Old Sep 10, 2015 | 07:40 PM
jmuenchow's Avatar
jmuenchow
I've read that the max is 1.1v then 1.2 v now 1.4 v idk which it is lol! Should I just play with it and stay within the 1.1-1.4 ball park and see which works best? Thanks, Josh
Old Sep 10, 2015 | 11:36 PM
akamacgyver
Clueless spectator!
I could be wrong about the 1.4, but yes, you need to adjust it until it is shifting where you want it too. it has a lot to do with your driving habits and load hauling. I have found the best way to do micro adjustments, is leave the bolts snug, and tap the fipl with a punch to move it slightly.
Old Sep 10, 2015 | 11:48 PM
jmuenchow's Avatar
jmuenchow
Okay I plan on advancing the IP timing a tad (will this affect anything?) and I will adjust the TPS tomorrow afternoon. I will be sure to give you an update. Thank you for your help!
Old Sep 11, 2015 | 06:08 PM
jmuenchow's Avatar
jmuenchow
I was able to pull a code 67
Texas27
May 4, 2018 04:14 PM
roycephus
May 26, 2013 10:37 AM
dieselcanuck
Nov 12, 2004 01:17 PM
MustangGT221
Sep 11, 2002 04:54 PM
