7 inch LED headlights
Click to Enlarge
Showing 1 - 4 of 15
View All Media
7" Round LED Sealed Beam Headlight - H6024 LED Driving Light
(1 Reviews)
Part Number: OR7-RHLx
UPC:
Select Finish:
Black
Chrome
In Stock
$129.95 ea.
See Quantity Discount Pricing
Qty
Share:
Orders Ship Today if placed before 2 p.m. CDT, 10 Hours and 10 Minutes remaining
Related Links
Application Photos
Specifications
Photos & Videos
Accessories
Reviews
Product Description
Lifetime warranty on all LED work lights. Upgrade your factory headlamps with these 7" round 91W driving light insert compatible with Jeep models, motorcycles with 7" halogen headlights, or custom applications. Has three functions; high beam (1600 Lumen), low beam (600 Lumen) and daytime running lamp (160 Lumen). Black painted aluminum housing with integral heatsink and PC lens. 13 x 7 Watt Philips Luxeon LEDs. 10~30 VDC operation, and IP69K waterproof light. Includes single light fixture, adjustable single bolt mounting bracket, 17in wire lead with H4 connector and all mounting hardware.
Standards and Certifications
Specifications
<table class="table table-condensed mbl" style="font-size:12px;"> <tbody><tr> <th class="active"> Bracket Thickness </th> <td> 3.07mm </td> <th class="active"> Color Temperature </th> <td> 6900 K </td> </tr> <tr> <th class="active"> Connection Type </th> <td> Push-On </td> <th class="active"> Current Draw </th> <td> 3000mA </td> </tr> <tr> <th class="active"> Diameter </th> <td> 7 in </td> <th class="active"> Diameter </th> <td> 7.0 in </td> </tr> <tr> <th class="active"> Efficacy </th> <td> 44 lm/w </td> <th class="active"> IP Rating </th> <td> Waterproof IP69K </td> </tr> <tr> <th class="active"> LED Brand </th> <td> Philips </td> <th class="active"> LED Color </th> <td> Cool White </td> </tr> <tr> <th class="active"> LED Lifetime </th> <td> 50000 Hours </td> <th class="active"> LED Quantity </th> <td> 13 LEDs </td> </tr> <tr> <th class="active"> LED Type </th> <td> Luxeon </td> <th class="active"> LED Wattage </th> <td> 7 Watts </td> </tr> <tr> <th class="active"> Length (in) </th> <td> 7.0in (0.58ft) </td> <th class="active"> Lens </th> <td> Clear </td> </tr> <tr> <th class="active"> Lumen </th> <td> 1600 Lumen </td> <th class="active"> Mounting Bolt Dimensions </th> <td> 12.85mm x 30.50mm </td> </tr> <tr> <th class="active"> Operating Temperature </th> <td> -40~+80 °C </td> <th class="active"> Polarity Sensitive </th> <td> Yes </td> </tr> <tr> <th class="active"> Standards And Certifications </th> <td> ROHS Compliant </td> <th class="active"> Suitable for Vehicles </th> <td> Yes </td> </tr> <tr> <th class="active"> Power Consumption </th> <td> 40.5 Watts </td> <th class="active"> Type </th> <td> Fixture </td> </tr> <tr> <th class="active"> Operating Voltage </th> <td> 10~30V DC </td> <th class="active"> Wattage </th> <td> 91 Watts </td> </tr> <tr> <th class="active"> Wire Length </th> <td> 43.1cm(17in) </td> <th class="active"> </th> <td> </td> </tr> </tbody><tfoot> <tr> <td colspan="4"> Dimensions: 17.655cm(6.95") x 9.235cm(3.64") x 17.655cm(6.95")
</td> </tr> <tr> <td colspan="4"> For off-road use only. All specifications are subject to change without notice.
</td> </tr> </tfoot> </table>
<table id="specTable0" class="display specTable initialized" border="0" cellpadding="0" cellspacing="0"><tr><th class="specTableHead_1 ui-state-default">Part NO
</th><th class="specTableHead_number specTableHead_128 ui-state-default">Lumen
</th><th class="specTableHead_number specTableHead_14 ui-state-default">Price
</th></tr><tbody><tr id="row_0_5270" class="odd"><td class="specTable_partno specTable_word sorting_1">OR7-RHLC</td><td class="specTable_number">600/1600/160 lm</td><td class="specTable_price">$129.95</td></tr><tr id="row_0_5269" class="even"><td class="specTable_partno specTable_word sorting_1">OR7-RHLB</td><td class="specTable_number">600/1600/160 lm</td><td class="specTable_price">$129.95</td></tr></tbody></table>
Dimensional Drawings
OR7-RHLx - 7" Round 91W Driving Light Insert with Bracket - High Powered LED Work Light
(Click to Enlarge)7" Round 91W Driving Light Insert with Bracket - High Powered LED Work Light
$129.95
7" Round LED Sealed Beam Headlight - H6024 LED Dr...
that means if you use them for headlights on the road the police can and probably will give you a ticket for them.
