Normal readings?
Old Sep 8, 2015 | 09:06 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
ICP of 640 and IPR of 25% might not be an HPO leak; with boost at 1+psi at idle it could be a turbo starting to be sticky and pushing too much air. Especially if you can mash the pedal and get it to go back down to 580/23% with a 0-0.5psi boost.
Mine runs at 580psi/22-23% normally, but it'll randomly decides it needs to go into the 620-640/24-25% range sometimes, seems like that happens if I mash it have to slam the breaks in traffic, and the VGT not getting back to where it wants is the best guess I can come up with, almost like it's idling with just a bare amount of throttle input.
Before you change any parts, I'd just carry a notebook and jot down the readings at idle a half dozen times or so over your trip home for a week or two.
Old Sep 9, 2015 | 05:47 AM
bizzelj's Avatar
bizzelj
This is what I got this morning on the way to work. Seen 22 and 21 for most of the time this is when I was parked
Old Sep 9, 2015 | 07:03 AM
white Buffalo's Avatar
white Buffalo
Do you test the 6.0L's HPOP the same way as the 7.3L? Datalog at WOT from 55 mph to 85+ and see if she can maintain the ICP at an acceptable duty cycle? Just getting started on my first 6.0L and trying to figure out what should be a normal stock reading.
trik396
6.2L V8
Nov 23, 2017 08:31 AM
1buckeyefan
Feb 18, 2011 02:15 PM
caseydudem
Dec 21, 2007 12:05 AM
dhelm72
Sep 9, 2005 12:50 AM
bug juice
16
Dec 9, 2004 10:17 PM
